Disco wrote:Clint man, have you had a wheel alignment?
it's commonly called tracking where one wheel will follow the road and not drive in a straight line - 101s are pretty bad for it - my one is nasty to drive after I put 17's on it.
new bushes help...
SKDABL wrote:Take it on the motorway and see when it starts shuddering
now the car jerks abit to the left/right when i go over bumps or down a driveway so does the steering wheel.
levin_it_large wrote:steering wheel starts shaking at about 80k's, is this alignment or balancing???
Banga69 wrote:well actualy is doenst really jerk it has a mind of its own.
nope its doesnt shudda on the motorway at over 100km/h so i know its not the balance.
so you say wheel alignment?
kingcorolla wrote:
this meens your suspension travel, is interfering with the tierod ends, therefor jerking left/right when suspension is traveling.
maybe the incorrect control arm? Anyone will tell you that "steering angles" is a big factor (and big subject!) in the cars operation. when one angle fukks out, it plays around with more angles, which can affect things like uneven load on bearings, handling ability etc etc
Disco wrote:Banga69 wrote:well actualy is doenst really jerk it has a mind of its own.
Well you were going to get one anyhow weren't you *glare*
Banga69 wrote:Disco wrote:Banga69 wrote:well actualy is doenst really jerk it has a mind of its own.
yup but just wanted to find out what is was dont wan aget an alignmnt then find out its coz on the lower arm.
10k 20v wrote:is it superstrut?
s.hand arm or new?
10k 20v wrote:there's the problem.
check all those joints again.
there only needs to be a small bit of play in those joints to totally stuff up the toe angles.
does it happen when you brake or accel
