ECU q?
ECU q?
Postby rollas22 » Thu Sep 30, 2004 1:51 pm
ive nearly finished the SIlvertop 4age 20v Turbo build.
Now ive got a LINK V4 to get wired in. But i wana know if i can run the complete turbo set up off the standard ECU to run the engine in untill i have time to take it to get wired up and tuned for the link???
it has different pistons and rings, td04 turbo, front mount and all the necacery turbo items, so will the standard ECU run this with low boost???
AFM has been removed too.
I really wana take her for a little run just to get the engine wearing in correctly before it goes to rotorua for the full on tune up.
KE-Corolla's for life!!!
rollas22
Postby Mr Revhead » Thu Sep 30, 2004 1:57 pm
i doubt it will run. especially since youv removed the a/f. wheres it gunna get a reading from?
just set it up on the link and if you wanna run it in, take it easy!
Postby 10k 20v » Thu Sep 30, 2004 7:38 pm
u got pm
10k 20v
Postby 10k 20v » Thu Sep 30, 2004 7:44 pm
it will not run and even if it did the fueling would be so far out your rebuild would be a waste of time.
u got pm
10k 20v
Postby rollas22 » Fri Oct 01, 2004 1:21 pm
thats exaclly what i thought! Oh well still gota wait a bit longer now :(
rollas22
Postby FLAWLES » Fri Oct 01, 2004 6:28 pm
trust 10k 20v that man nows his stuff :wink:
FLAWLES
