will a 4agze fit in a....
Postby mr bmw » Sat Oct 09, 2004 1:02 pm
will the beautiful 4agze fit into a kp series starlet,
minus all the non esentials ie. heaters,air con etc.?????????
if i does fit it would be a tight squeeze but would be a hell of alot of fun!!!!
APPARENTLY, THE WORD "NON-FLAMMABLE" IS NOT MEANT AS A CHALLENGE TO ME... HUH, LEARN SOMETHING NEW EVERYDAY!
mr bmw
Postby Lloyd » Sat Oct 09, 2004 1:14 pm
Anything will fit anywhere, its just a bit of extra work to get something big into a small hole. Just have to look at Minis with 4AGEs, B16As and even V8s to see that. If you're prepared to do the work then you can do it
Postby l1ttle_d3vil » Sat Oct 09, 2004 3:05 pm
20V 4age into a KP61 - http://au.geocities.com/quibel_nz/
this guy is on the forums somewhere too. not sure how much help that would be though...ive just sat my 16V in my ke35 engine bay and it almost bolts straight and the starlet should be the same.
