3sgte injectors......help required
Postby capri007 » Fri Oct 15, 2004 12:06 am
i have a 18rgeu with 3tgteu injectors and i need more fuel as i have a feeling that it is going to run lean. at the moment i am boosting 5 psi and when i get my heavy duty clutch i am planning on turning that up to 9/10psi. which will be in the next week or so.
what i am wondering is do 3SGTE injectors have the same fittings as 3tgteu, or in other words will they fit directly into my inlet manifold with out leaking????????
if not the next option will have to be extra injectors but i have a large piece of samco hosing that i would prefer not to cut up and it is pretty tight so any help would be greatly appreciated.
thanks
mmmmm hello turbo capri, show us ya growler ;-)
capri007
Postby Twolitre » Fri Oct 15, 2004 12:25 am
2nd generation onwards 3SGTE injectors are side feed so forget them but if you can get your hands on a set of ST165 3SGTE or MA70 7MGTE injectors which are the same thing then you should be onto a winner.
Twolitre
Postby Malcolm » Fri Oct 15, 2004 8:43 pm
I happen to have a set of 6 7MGTE injectors, 430cc/min, top feed, low impedance, all yours for $200.
Postby wde_bdy » Fri Oct 15, 2004 9:21 pm
The common upgrade for 3T-GTE's is RX7 injectors around 550cc. Can't remember which model but a quick search of the net should find the info.
Callum
wde_bdy
Postby capri007 » Sat Oct 16, 2004 8:11 pm
so are st165 injectors the same fittings as 18rgeu?? if they are they might be the go.
capri007
