Broken Heater
Broken Heater
Postby Audi » Fri Oct 15, 2004 4:33 pm
I'm not to stressed about this as summer is coming up but the heater in my car is broken. Like it still pumps out air, but whn you turn it to hot it doesn't get any warmer. Any possible things I could look into fixing? Its in a GT4 by the way.
Dig a hole for the next man and you'll fall in.
Audi
Postby Zak » Fri Oct 15, 2004 5:01 pm
Have you tried bleeding your cooling system? It might help it.
Zak
Postby rollaholic » Fri Oct 15, 2004 5:33 pm
locate the heater tap and make sure its moving when you flick the switch - might need a helping hand for this :)
i couldnt tell you for sure on a GT4, but in my experience its usually located on the firewall somewhere
Postby matt dunn » Fri Oct 15, 2004 6:38 pm
ever had bars stop leak in your radiator?
If so it's blocked your heater core because thats what it does.
Postby vvega » Fri Oct 15, 2004 6:43 pm
lol
any of that shit $&#$% everthing
specially the head gasket in a bottle stuff
v
vvega
Postby Dr-X » Fri Oct 15, 2004 6:56 pm
stop leak killed my escort :(
Anyways, I'd be suggesting, as above, it's an issue with the heater 'tap'. As already stated, it's usually mounted on the firewall.
Dr-X
Postby Audi » Mon Oct 18, 2004 4:00 pm
Never had anything like that in it as far as I know. What would this tap look like?
Audi
Postby Audi » Wed Oct 20, 2004 9:35 am
Anyone?
Audi
Postby Zak » Wed Oct 20, 2004 1:06 pm
It's a little black box with a lever on top and a cable the conects to it going into the dash, I'll try and get a pic of mine if you want.
Zak
Postby Audi » Thu Oct 21, 2004 11:20 am
That'd be excellent, thanks!
Audi
Postby Audi » Tue Nov 02, 2004 11:15 am
Any luck with that?
Audi
