Mmm, Boost wrote:Trim depends where you measure it from I believe...but if they mean .60 trim in the usual usage of it, thats a big mofo compressor
Mmm, Boost wrote:I've been told there isnt much point porting the wastegates on CT26's, as the twin poppet wastegate is quite sufficient (even though mine was ported, I'm not 100% sure why they did it)
MrBob wrote:Mmm, Boost wrote:I've been told there isnt much point porting the wastegates on CT26's, as the twin poppet wastegate is quite sufficient (even though mine was ported, I'm not 100% sure why they did it)
just noticed this second point.. it would be a good idea to get the wastegate machined out...or just run a small external. The standard wastegate is NOT SUFFICIENT as is evident by the fairly etreme boost creep that occurs when you fit a decent unrestrictive exhaust (on an sw20) if its on a gt4 the creep is pretty minimal.
generally speaking, upgrading a ct26 is a fairly pointless exercise, and its money better spent elsewhere..
Mmm, Boost wrote:Hmm, its strange I got conflicting advice on this...the performance place that did my turbo said it needed doing as it was creeping badly (I do have a 3" exhaust off the cat, 2 mufflers) yet when I rang them a couple of years after it being done they said it wasnt necessary at all. Odd.
Lanius wrote:High 12's on stock internals?
Users browsing this forum: Bing [Bot] and 19 guests
