Oil Catch Can in a 20v 4AGE Turbo silvertop
I know that i plumb the can off the rocker cover into the can then out to ???
thats the bit i would like to know where does it go after its entered the can?
a diagram would be great!
Disco wrote: but you can plumb it back into your intake for vacuum purposes in which case it will need to be sealed to work properly
If you want to vent your pcv valve to the can as well then you will need a sealed unit and run that from the pcv valve (and run that to the can and then back into the vacuum line .
matt dunn wrote:Disco wrote: but you can plumb it back into your intake for vacuum purposes in which case it will need to be sealed to work properly
What's the point of that?
The vapours are still entering the intake.
The whole point of fitting a catch can is to prevent the vapous from going into the engine as the vapours have the effect of lowering the octane rating of your fuel, that is the vapours cause detonation.
