Certification for Roll Cages and Seatbelts/Harnesses
Postby MattrickMotorsport » Thu Oct 21, 2004 8:34 pm
Apparently MIld has a better impact rating or something
My Rolla is pretty much like your cage
MattrickMotorsport
Postby Leon » Thu Oct 21, 2004 8:39 pm
moly is quite brittle ... so it's as strong as hell, but then is more likely to "snap" than mild.
If you are looking at 38mm x 2.5mm mild tube, it will have a tensile mpa of just under (or around) 400, while with moly the same tube with a 1.6mm wall thickness will be up around 800. So 1/3 thinner, but twice the "strength".
Add a zero to your material costs though 8O
Postby Boost_4_Life » Thu Oct 21, 2004 10:33 pm
ok looking at finishing the cage in the dat before this event, what sort of price would be a a guide for the front of the cage? ( already has half cage) Thats including a bar down either side ( along roof and to floor), side intrusion bars, one across the front, and a couple of bars in the roof. Dash will already be removed. Just tryin to get an idea of approx cost, cos i've had varying quotes :?
'83 KP starlet rally car, 20v powa!
The rally beast
The rally beast again!
Boost_4_Life
Postby Leon » Fri Oct 22, 2004 9:25 am
it'll vary depending on who you go to ... I would guess at a $500 or so ballpark figure.
Maybe try Automotion, or another constructor in your area.
Postby Boost_4_Life » Fri Oct 22, 2004 9:29 am
$730 incl gst is best ive had so far, not bad i guess. Its only money when it could save your life :) I'll keep lookin round tho.
The rally beast
Boost_4_Life
Postby Leon » Fri Oct 22, 2004 1:21 pm
My entire cage cost me $900 + gst!
Six point, single intrusions, extra triangulation from main hoop to rear stays, and a harness / rear strut tower bar.
Postby GT4 20 » Fri Oct 22, 2004 1:59 pm
Leon wrote:My entire cage cost me $900 + gst!
Bargain
About 2500 inc for mine. 8 point with bars for Africa. All beautifully tig welded :D
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Leon » Fri Oct 22, 2004 2:03 pm
Bargain
Gary
Thats $400 more than I paid for my entire car ;)
Obviously it owes me a bit more than that now 8O 8O 8O
Postby Boost_4_Life » Fri Oct 22, 2004 2:10 pm
shit yea 900 is good. this will end up a 6 point cage too, with double intrusion bars and all the jazz. Hey leons whats the story with rallysprints etc, unless otherwise stated in the event regs you dont need WOF/REG eh, just logbook? Are most rallysprints run to this format?
The rally beast
Boost_4_Life
Postby Leon » Fri Oct 22, 2004 2:43 pm
Boost_4_Life wrote:sh*t yea 900 is good. this will end up a 6 point cage too, with double intrusion bars and all the jazz. Hey leons whats the story with rallysprints etc, unless otherwise stated in the event regs you dont need WOF/REG eh, just logbook? Are most rallysprints run to this format?
Rally sprints are a funny one, because they require a navigator, therefore full cage, harness' etc.
*usually* only require logbook, rollcage.
*sometimes* require logbook, rollcage, reg wof etc. Because there are two types of road closure that are applied for, and one of them still requires that all cars used are all road legal. The other type of closure means you can run what you brung. So yes, as you say, read the event sup regs very carefully.
That particular one does trip up a few people with vehicles that are no longer road legal, and don't read the sup regs.
Postby MattrickMotorsport » Fri Oct 22, 2004 10:40 pm
Bargain
Gary
Damn mine was 1600inc
Cage pretty much like yours PLUS seat mounts and seatbelt anchor points for 5 point ALSO Custome aluminium lightweight dash! PLus heaps more :D
MattrickMotorsport
