Squealing
Squealing
Postby GTSMR2TURBO » Fri Oct 22, 2004 4:53 pm
Any1 one know why every time I turn left in my sw20 it makes a weird squealing noise but when I turn right it doesn't any Ideas ???
Current Ride - 1993 GTS MR2 (K&n pod, HKS bov, Toms Kit)
GTSMR2TURBO
Postby Lloyd » Fri Oct 22, 2004 5:34 pm
Like belt slippage noise? Check how tight the power steering pump belt is
Postby Ae92typeX » Fri Oct 22, 2004 9:10 pm
Are you talking full lock for the noise to occur?. Could be something to do with the return feed from that side of the p/s
Ae92typeX
Postby Sanxta » Sat Oct 23, 2004 4:22 am
yeah something to do with the PS belt? but then you would tink it would do the same when you turn the other way too . . . ?
Sanxta
Postby GTSMR2TURBO » Sat Oct 23, 2004 10:19 am
as far as Im aware MR2's run on an electric motor in the front so there are no powersteering belts thats whats got me baffled
GTSMR2TURBO
Postby vvega » Sat Oct 23, 2004 11:13 am
might be a full lock buzzer :S
hmm
yeap thats all i got
v
vvega
Postby Adamal » Sat Oct 23, 2004 11:57 am
Is it only while moving or does it happen when you're stationary as well.
And yes, MR2's have electric power steering... If they have it
Postby levin_it_large » Sun Oct 24, 2004 9:14 am
the starting of a collapsed wheel bearing??
levin_it_large
Postby GTSMR2TURBO » Sun Oct 24, 2004 3:57 pm
it's when I am moving and only around 50-60 km/h does it both ways now left and right and its any slight turn
GTSMR2TURBO
Postby FallenGtz » Thu Nov 11, 2004 11:48 pm
im having the same probs, gonna remove the power steering belt to try and isolate the prob, have u had any luck with it?
FallenGtz
Postby matt dunn » Fri Nov 12, 2004 8:53 pm
FallenGtz wrote:im having the same probs, gonna remove the power steering belt to try and isolate the prob, have u had any luck with it?
SW20 do not have a power steer pump.
SW20 do not have a power steer belt.
Postby Al » Fri Nov 12, 2004 9:27 pm
yah mr2 have electro-hydraulic power steering
they have an electrically controlled pump in the front of the car
Al
Postby GTSMR2TURBO » Sat Nov 13, 2004 10:07 am
Yeah it's really weird it's not a really loud sound it's quite faint really and seems to me coming from the back of the car ????? Im :?
GTSMR2TURBO
Users browsing this forum: Google [Bot] and 20 guests
