BZG Wagon wrote:VVT vs VVT-i - Whats the difference?
From what I have gathered, VVT comes on at a predetermined rate and VVT-i come in based on throttle position.
Which one is better / more power? Pro's Con's of each? Is there much difference?
CozmoNz wrote:so at full throttle, they are equal!
matt dunn wrote:CozmoNz wrote:so at full throttle, they are equal!
at some point in the rev range yes,
but at full throttle VVT-i will vary with revs to maintain max power throughout. It's not alway max advance = max power.
CozmoNz wrote:
anyway to get a controller that can switch you from vvt to vvt-i?
ants_ae92 wrote:There are 2 types of silvertop 20v. The early model - Same switching point. And a later one. I think the early is pre may 1993 or something like that.
The later one you guys are describing is load based. Or whatever.
read this on bill sherwoods site. Whether its true, who knows.
