4agze's run rich at full throttle/boost - this makes the smoke.
It is set up like that at the factory to make (very) sure that it won't run lean.
I think the 4agze at full throttle the computer doesn't use the oxygen sensor to set mixture, it uses a fuel map in it's memory.
Dr-X wrote:Kinloud, you're not the brightest crayon in the box, eh?
Dr-X wrote:Kinloud, you're not the brightest crayon in the box, eh?4agze's run rich at full throttle/boost - this makes the smoke.
So you're telling me these cars blew smoke coming off the showroom floor? Ok, dude...I think the 4agze at full throttle the computer doesn't use the oxygen sensor to set mixture, it uses a fuel map in it's memory.
No engines use the O2 sensor at WOT.
vvega wrote:Dr-X wrote:Kinloud, you're not the brightest crayon in the box, eh?4agze's run rich at full throttle/boost - this makes the smoke.
funny thing is nethier are you
he said that they dont use the o2 and you bagged him for it
saying the same thing
maybe if you read what people said and didnt just try to bag people all the time you might learn something and not end up looking like a complete $$%
and hers a shocker
lots of early turbo cars smoke from factory
its part of tring to cope with somany prefactored countrys conditions
so both ya comments are about as clever as you
heres some advice
its better to shut ya hole and let people think your a idiot than open your mouth and remove all doubt
much liek you just did
v
