RADIATOR PRESSURE
RADIATOR PRESSURE
Postby FYADUP » Sat Oct 30, 2004 8:40 pm
do u need the same pressure radiator cap as the standard unit?
My ae92 uses a 0.9bar cap, if i am to replace this, can i use a higher or lower pressured cap???
R.I.P - 90 4AGTE GT-i Corolla Hatch [ROLYOU]
New 91' Corolla GT-i project! WATCH THIS SPACE
FYADUP
Postby TygerTung » Sat Oct 30, 2004 9:00 pm
Well, toyota spent millions of dollars and years of research working out which radiator cap pressure to use.
Why change it?
TygerTung
Postby Lloyd » Sat Oct 30, 2004 10:35 pm
Yeah, whats the point? You dont need to use the same one but if you use higher pressure then there more chance of your radiator/cooling system failing due to excessive pressure, and if you use a lower one then it might start spitting coolant out when it doesn't need to.
Postby dskd » Sat Oct 30, 2004 10:41 pm
what rong with going to toyota or super cheap ect and gettting a 0.9bar cap
u less u have done some mod wise to u cooling system y chang what works ?
dskd
Postby vvega » Sun Oct 31, 2004 10:36 am
trd makes a 1.4 bar
and toda makes a 1.7 bar
less pressure is bad
the reason it presurises to to raise the boiling point of the fuild inside the system
so more presure keeps the fuild from boiling under higher temperatures
hope that helps even slightly
v
vvega
Postby ChaosAD » Sun Oct 31, 2004 5:59 pm
Are there any disadvantages to using a higher pressuer TRD radiator cap?
ChaosAD
Postby Dr-X » Sun Oct 31, 2004 6:19 pm
Extra strain on your cooling system. If your hoses, waterpump etc arent up to it, you could run into problems.
Dr-X
Postby Mr Revhead » Sun Oct 31, 2004 6:38 pm
as vvega stated, a higher pressure cap allows the cooling system to run the coolant at a higher temp before boiling.
so its really only going to be worth it in a race application where theres a lot more heat. if you were running a race car and had problems with the coolant boiling then a higher pressure system may help.
if the coolant system is in good condition then there shouldnt be any problems.
Postby CozmoNz » Mon Nov 01, 2004 6:02 pm
if it aint broke, dont fix it :).
i think someone wants some rice ^_^ awww how cute
Rayne For President!
CozmoNz
