Corolla help urgent!
Postby SKDABL » Thu Nov 04, 2004 10:40 pm
Today when i turned my car off at the key, it continiued to go for about 4 seconds then made a loud hissing noise from the enginebay and it smells like petrol real bad.
anyone got any ideas on whats happened?
car: 1989 toyota corolla
engine: 4a-f
mods: ramflo air intake, simota breather filter
thanks heaps!
1989 Mitsubihi Mirage Cyborg RS 4g61t 1.6l Dohc turbo
SKDABL
Postby malc » Thu Nov 04, 2004 10:45 pm
does it still start?
malc
Postby SKDABL » Thu Nov 04, 2004 10:53 pm
yup, it starts fine, just when i turn it off it does it everytime...
throttle body dirty?
but how does that explain the hissing noise and the gas smell?
SKDABL
Postby Ae92typeX » Thu Nov 04, 2004 11:00 pm
Is your filter setup new?- that will create a hiss as the engine turns off- all my engines with any type of pod have done that.
As for the running on, make sure all your timing etc is correct, also check your plugs to see if it appears to be running rich or not.
Ae92typeX
Postby TygerTung » Thu Nov 04, 2004 11:05 pm
Perhaps your timing is too retarded, that can cause running on as you describe. Also known as deisling.
TygerTung
Postby kingcorolla » Thu Nov 04, 2004 11:38 pm
running on is where the engine fails to stop when ignition is cut, causes can be by hot spots in combustion chaber, incorrect timing, wrong plugs, fuel cut solenoid failure, too high idle speed or maybe an overheated engine.
And a hissing noise with a ranflow is not suprising, especially if your motors running on 8O
just check the things people have listed asap
dieseling is a type of abnormal combustion, and should not be ignored as it can do serious damage 8O
1983 Carina AA63 4age
kingcorolla
Postby SKDABL » Fri Nov 05, 2004 6:04 pm
it only started happening when i put my ramflo air filter on, someone suggested i got an oil breather filter, so i did, nothing changed.
when i put my stock air filter set up on it doesnt hiss or anything it runs perfect.
there is no set idle when the ramflo is in, it drops to 400rpm then goes up to 1600rpm then drops again by itself when it idles.
drives fine... then you turn it off and it begins to running on and then hisses really loud.
will carb cleaner do anything?
ill check those things out tomorrow.
thanks for all the help guys!
SKDABL
Postby ee904age » Fri Nov 05, 2004 8:06 pm
Next time it does it, If you are qiuck enough, put it in 1st and slowly release clutch. I think you will find you go backwards! Yeah its usually a timing related problem. Check all vacuum hoses etc coz the hiss may be one blowing off under positive pressure
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby BL8KK9T » Fri Nov 05, 2004 11:19 pm
i had the same problem with one of the cars at work, it trys to run backward, we end up replacing the igniter, dont ask me why it beat me :? but it fixs it....
yes officer, our sober driver is right behind us
BL8KK9T
Postby BL8KK9T » Fri Nov 05, 2004 11:23 pm
and maybe something to do with the idle jet or something,,,, now that you getting more air but the idle jet is still the same size it may cause the engine to run lean and causing the deiseling, just a guess hope it helps :wink:
BL8KK9T
Postby TygerTung » Mon Nov 08, 2004 2:31 am
Perhaps it is your ramflow.....
Does it make it go any faster?
TygerTung
Postby SKDABL » Mon Nov 08, 2004 8:07 am
no performance increase i can feel...
just the noise it makes is why i bought it.
I bought some carb cleaner and it hasnt hissed since and doesnt "run on" for as long either.. still runs on, but only for a short period of time, if it starts hissing again ill get it checked out immediatly/
SKDABL
Postby SKDABL » Mon Nov 08, 2004 7:52 pm
ee904age wrote:Next time it does it, If you are qiuck enough, put it in 1st and slowly release clutch. I think you will find you go backwards! Yeah its usually a timing related problem. Check all vacuum hoses etc coz the hiss may be one blowing off under positive pressure
Did this today after work so i tried it, car did go backwards in 1st gear! i was like WDF?
getting it checked out tomorrow, wonder how much it will cost me, if its more than i paid for the car im gonna sell it... :cry:
SKDABL
Postby kingcorolla » Mon Nov 08, 2004 8:05 pm
yes your car will go backwards, thats because the ENGINE is rotating BACKWARDS!!! thats the hissing noise you are hearing, air getting shot up through the carb
kingcorolla
Postby Adamal » Mon Nov 08, 2004 9:05 pm
UH OH. That can't be good...
Sounds like your cam belt could have slipped a few teeth maybe... Although that would make it run funny....
Hmm... It's got me thinking now.....
