92GTApex wrote:has about 85mm clearance at the lowest point which isnt too bad
phat_levin wrote:92GTApex wrote:has about 85mm clearance at the lowest point which isnt too bad
isnt that illegal? i thought the lowest you could go was 100mm?
snwtoy wrote:phat_levin wrote:92GTApex wrote:has about 85mm clearance at the lowest point which isnt too bad
Only on chassis parts - you're sweet if your body kit / exhaust is 20mm off the ground.. how long they last is another matter of course...
Dr-X wrote:snwtoy wrote:phat_levin wrote:92GTApex wrote:has about 85mm clearance at the lowest point which isnt too bad
It's not just chassis. Any structural part, or any part to do with steering or suspension.
