Bedding in rings after 20v rebuild. Anyone had problems?
Postby 85AW20v » Thu Nov 04, 2004 11:36 am
The 20v in the racecar is in need of a rebuild. Anyone had any problems with the rings not bedding after replacing them and giving the bores a hone? Any tips to ensure that they do bed in properly gratefully received.
See ya
Simon
85 MR2 20v
85AW20v
Postby evil_si » Thu Nov 04, 2004 12:14 pm
use a good mineral oil, dont use synthetic during run / bed in,
evil_si
Postby Tranquil » Thu Nov 04, 2004 2:51 pm
evil_si wrote:use a good mineral oil, dont use synthetic during run / bed in,
whats a good run in period ? 1000-1500k ?
Tranquil
Postby vvega » Thu Nov 04, 2004 4:58 pm
sould only take 50 km's for the rings to seat at the most
normally a cain around the block and its all sweet
just run a good mineral 15-50
change it after a good drive
new filter ,oil
and thats it
people think you have to baby a new engin
witch to a point is true
im normally nice for the first 50km's
then its just a nother engine
ive never had a engine fail yet
v
vvega
Postby Dr-X » Thu Nov 04, 2004 5:23 pm
Newer japanese parts are designed well, and as vvega says, bed in after far fewer k's than most believe. It's critically important to change the oil/filter after your bed in period. I'd probably do the oil/filter after 100km.
Try not to idle for too long during your bed in process.
Dr-X
Postby 10k 20v » Thu Nov 04, 2004 6:37 pm
and the key to success with any engine freshen up is CLEANNESS
Mine didn't use any oil at all after my rebuild "untill it mashed a hole in the top of the piston when the valve retainer broke :D )
10k 20v
Postby ChaosAD » Thu Nov 04, 2004 9:16 pm
8O What caused that?
ChaosAD
Postby vvega » Thu Nov 04, 2004 9:22 pm
franklen cams shoddy work
v
vvega
Rings
Postby GOLDAE86 » Thu Nov 04, 2004 9:48 pm
If using A crome top ring use minimal oil when pistons are being inserted to bore, also done give the bore a corse hone.
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby Tranquil » Fri Nov 05, 2004 9:48 am
Sweet thanks for that. How about bearings ?
Ive been, taking it easy for 1000+ on myne.
Tranquil
Postby evil_si » Fri Nov 05, 2004 12:29 pm
yea same for bearings, bearing are dependant on good oil and pressure,
dont idle the engine for more than a couple of minutes thou, idle time is a killer, bores glaze up etc
as long as you have good oil, and good oil pressure it should be fine, if you dont have oil pressure something is wrong and it wont fix it self, so apart she comes.
with the heavy diesels i build, on the first run or dyno run it is loaded up as much as possible, full horsepower, full torque, max rpm. thats done when the engine first gets up to operating tempurature, no being leniant. no idle time.
i always change the oil and filter after say 250km, then at 1000km, them just every 5000km as normal.
for the first couple of services i just run a good mineral 15w-40, then i go back to the good ole syntetic 5w-50, unless its my batty then mineral oil permanently
evil_si
Postby ChaosAD » Fri Nov 05, 2004 12:38 pm
vvega wrote:franklen cams shoddy work
v
You been having problems with them too?!!
Is it anything we should know?
So how do most people tune thier engines if they cant rev them past 4,500rpm?
Do they just give it a basic tune, then tune it properly once its fully run-in?
ChaosAD
Postby Tranquil » Fri Nov 05, 2004 1:12 pm
So you went straight to a syn? My mech recons a mineral for the run in, then semi-synth, followed full synth.
I dont think there a definitive method to running engines in. everyone seems to have different methods :)
Tranquil
Postby JT » Fri Nov 05, 2004 4:35 pm
Tranquil wrote:Sweet thanks for that. How about bearings ?
http://www.mototuneusa.com/break_in_secrets.htm
Very interesting read. He doesn't just sprout random statements without research, most of his work is with motorbikes but it most of it applies to car engines too.
What he says agrees with vvega, rings only take a short period of time to break in. Bearings don't need wearing in, so go for it!
JT
Postby ChaosAD » Fri Nov 05, 2004 5:31 pm
JT wrote: Bearings don't need wearing in, so go for it!
Theoretically
ChaosAD
Postby 10k 20v » Fri Nov 05, 2004 6:10 pm
v
i'm not into to bagging firms aye, pm me for details
10k 20v
Postby vvega » Fri Nov 05, 2004 7:08 pm
Theoretically
i be;ive in the 50kms method :)
v
vvega
rolcage
Postby vvega » Sat Nov 06, 2004 11:46 pm
can you please send me some picks of your roll cage
with details of hoop shots etc :d
cheers for you help if you can
kdalton@xtra.co.nz
wayne
vvega
Postby TygerTung » Mon Nov 08, 2004 2:35 am
I reckon, give it shit after it's warmed up a bit eh, and chabnge the oil soon as, like 10-20km, just use shitty warehouse stuff.....
Change it again at 100, then 250, 500, and 1000.
TygerTung
