wana lock ae85 diff
wana lock ae85 diff
Postby kyle » Sun Nov 07, 2004 7:59 pm
i wana lock my ae85 diff will it handle it? and is there a special way u have to weld it?
kyle
Postby NZ_AE86 » Sun Nov 07, 2004 9:20 pm
Should be ok! But you can break anything! :D
Just weld the spider gears to the side gears, should end up with eight seperate welds. Try to clean all the oil off before welding. :)
NZ_AE86
Postby kingcorolla » Sun Nov 07, 2004 9:25 pm
just go wild with the welder. Even melt up a few bolts if you have to.
just be sure that it rotates afterwards!
1983 Carina AA63 4age
kingcorolla
Postby Dr-X » Sun Nov 07, 2004 9:49 pm
And I'm hoping this is for the track, as welding a diff is extraordinarily dangerous on the road. Anyone remember the case a few years back, when some dumb $&#$% locked his diff, causing too much strain on the axle and related assembly. Hub ended up breaking loose, hitting and killing a young child.
Dr-X
Postby fangsport » Sun Nov 07, 2004 9:52 pm
cut 2 plates to fit inside the spider gears and weld it up, it pays to heat the gears with a bit of gas to ensure to oil is burnt off and enables better weld penetration. welding the gears only makes you vunerable to failure and rooting the CW/P, sending steel gears and oil out through back of the housing .
fangsport
Postby MetalupYoAss » Mon Nov 08, 2004 5:47 pm
i got a nite parts lock diff for sale if your interested
MetalupYoAss
Postby kyle » Sat Nov 13, 2004 5:58 pm
chers dudes was a big help
kyle
Postby suberimakuri » Wed Nov 17, 2004 11:21 am
exactly.. your wheel will wobble around a bit, but the hub is still bolted to the housing.
haven't seen broken spiders.... if it's all welded to the casing, and too each other, then it should be stronger then the axle.
suberimakuri
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 11 guests
