help: 3sgte boost / "hesitation" at multiple point
Postby Inane » Mon Nov 08, 2004 1:16 pm
whatever the problem, I seem to be having it too
where did you last get your fuel from??
although my car seems to be running 7psi at the moment...
it only gets above that when I plant the foot and it'll spike up to 13-15 psi...
any ideas with that?
Inane
Postby TWSTD » Mon Nov 08, 2004 1:39 pm
last lot of fuel from BP fanshaw st mid to late last week.
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby Inane » Mon Nov 08, 2004 1:41 pm
== last lot of fuel BP Johnsonville.....
I usually never use bp, I almost always go with Mobil synergy 8000
Inane
Postby HERGTT » Mon Nov 08, 2004 1:45 pm
.....last lot of fuel was from MOBIL Wairau Road (Nth Shore), and yes I run it on Synergy 8000 too :D
I'm pretty sure it's the plugs tho, not the fuel.
HERGTT
Postby YTWGN » Mon Nov 08, 2004 2:24 pm
Havent had any problems with MOBIL on constellation. Havent tried any others.... yet.
YTWGN
Postby MrBob » Mon Nov 08, 2004 3:47 pm
TWSTD wrote:I do have my suspicions re the plugs being the cause however as it is ONLY when im at about 0.3 bar boost or above that this problem occurs and does not seem rev related at all (i can happily rev to 6000rpm slowly without any sign of the problem).
yes, this is exactly how it was with mine. No prob off boost.. under boost the weak spark just isnt doing the job, hence the hesitation and missing.
MrBob
Postby vvega » Mon Nov 08, 2004 6:48 pm
id have to agree with that
my old gto used to eat plugs and that was the signal they were $&#$%
i tened to crack the cermic on them :S
v
vvega
Postby anthonym » Mon Nov 08, 2004 8:21 pm
I would suggest the rash of GT-T issues as described in this thread is more likley due to a recent significant increase in amibent temperature that fuel octane, although perhaps not for those in (subantarctic) Welly :D.
The GTT is pretty much on the detonation threshold even on 98 and the air temps over the past few days here in AK will be pushing it even further. Knock-induced retard is hard on ignition components, and as others have noted the symptoms described indicate spark plug problems.
anthonym
Postby fivebob » Mon Nov 08, 2004 9:35 pm
I'd second Nemesis's opinion on the likely cause of this problem, and add that in most cases I doubt that the plugs are really the problem. Modern plugs are more than capable of the requirement exacted by turbo engines, though TWSTD's plugs seem a bit on the cold side.
Also the stop start nature of the problem described points to something other than a plug misfire. Which, once they start misfiring from excessive combustion pressure, tend to continue to do so, and in most cases would be accompanied by a backfire or two from the unburnt fuel in the exhaust system.
A simple way to see if the ECU is detecting knock is to monitor the signal going to the Turbo VSV.
Postby Inane » Tue Nov 09, 2004 8:46 am
fivebob wrote:A simple way to see if the ECU is detecting knock is to monitor the signal going to the Turbo VSV.
please explain :)
actually fivebob, I'd like to arrange to plug your brain into something I can download all that useful information into....
Inane
Postby TWSTD » Tue Nov 09, 2004 12:24 pm
pulled plugs and heres what they look like... distinct rust colour to them - even more than shows in the image... what causes this type of phenomenon?
Click here!
TWSTD
Postby Inane » Tue Nov 09, 2004 12:27 pm
how old are your plugs?
Inane
Postby TWSTD » Tue Nov 09, 2004 12:39 pm
about 6-8 months. Why?
Click here!
TWSTD
Postby vvega » Tue Nov 09, 2004 12:59 pm
iridiums have quite a massive life more so that platuims
and it is normmally a good idea to change em when you do a cam belt
i guess youve already don that
there still firing as the cleanness of the electrode shows
though id have to say that gap from this perspective looks massive
to me the color just looks like its a old plug with many km's worth of deposits and use
but its not
ive service quite a few fresh imports and they tend to have a redish look as well
i would have thought that it would have looked a little more blackish running on nz fuel though
my thoughts
change the plugs
eleminates one possibile issue
in my experiance iriduims are easly damaged by det
then work from there
factory ecu's are mapped to deal with a wide range of intake temps in hotter conditions than this
and if this is the problem there would be a rash of questions relating to this every year
in fact toyota would be overrun with them right now with unknowing owners wanted ther cars fixed cause there gunna blow up
ive rung teh waikato toyota workshop and they have none in there with your problem
just my thoughts
v
vvega
Postby TWSTD » Tue Nov 09, 2004 1:05 pm
thanks for your input vvega - appreciated. Will try other plugs tonite n see how it goes. The gap was 1.1 rather than the 0.8 i thought it was - and now i do recall gapping them up again to the 1.1 that they came set at as it felt better to drive than the smaller gap (unlike my mitsis 4g63/4g93 engines which i found much better on a 0.7-0.8 gap at most).
Click here!
TWSTD
Postby anthonym » Tue Nov 09, 2004 4:52 pm
TWSTD wrote:thanks for your input vvega - appreciated. Will try other plugs tonite n see how it goes. The gap was 1.1 rather than the 0.8 i thought it was - and now i do recall gapping them up again to the 1.1 that they came set at as it felt better to drive than the smaller gap (unlike my mitsis 4g63/4g93 engines which i found much better on a 0.7-0.8 gap at most).
0.8 is standard for the gen 3 3SGTE. I'm not sure if the coil over plug DFI system is any better, but I've had the exact problem you described when a clown put plugs with a 1.1 gap in my car.
anthonym
Postby anthonym » Tue Nov 09, 2004 5:00 pm
vvega wrote:factory ecu's are mapped to deal with a wide range of intake temps in hotter conditions than this
The GT-T is a JDM model mapped for 100 octane fuel, it runs a high compression ratio, has a poor intercooler, and the engine is subjected to high loadings as a result of the AWD system. Running it on 98 (or worse 96) in warm weather will push the factory knock control to the limit, and in some cases past the limit, as evidenced by the (at least) 2 people on this board have detonated GT-Ts to death.
anthonym
Postby vvega » Tue Nov 09, 2004 5:07 pm
nasty
point taken
but at any load ???
thats one big issue they need to adress
i dont know the car inside out i was more just looking in gereral factory terms
v
vvega
Postby anthonym » Tue Nov 09, 2004 5:44 pm
vvega wrote:but at any load ???
v
The load would need to be relatively high to cause problems, and a sustained thrashing, particularly on a hot day, appears to be required to pop the engine :D. And Toyota have addressed it partly, IIRC inadequate fuel has been cited as the reason we don't get many of the real performance cars here new, why they think it's OK to sell them Signature class is anyones guess.
anthonym
Postby H1S_SUB » Tue Nov 09, 2004 8:23 pm
so i changed the plugs in the caldina tonight a may have found the soultion to our common spark plug problems .
when i remove the coil from the engine i notice alot of condensation around the sharft of the coil pulled the plug and it was rusted and wet with water i believe the common problem that we have is there is a rubber o ring around the bottom of the coil which in my case wasnt fully sealed beacuse of general dirt in the rocker cover, some how water probably when i wash the car the other day has tracked down the coil and even down the thread of the spark plug into the bore causing the trouble, so i replace the plugs with a new set of lazer platinums, and all is well. on top of that, another story went to ripco the platinum seem to be the only plug available for the gen iv 3sgte that was on their computers , so me being a know it all said that i knew of someone running irriduims in their caldina (twstd) and he told me that they were in a 1.1 gap and not .8 another funny thing was the plugs in the car before i pulled them out looked like they were copper which aparrently they dont even do for a caldina, he tried to tell me the car was to new he went on a bit to about recomending 5s instead of 6s so here are some pics
its hard to believe that they have only done 3000km
H1S_SUB
