tureno creeking sound when steering turned S/S
Postby event2 » Mon Nov 08, 2004 9:48 pm
hey i got a ae 101 gtz tureno with super strut. now the problem is when i turn my sterin wheel within 45 degrees of center i can hear a sort of creeking sound but past a bout 45 degrees eather lock its fine no sound at all now it seems to hav started after it was put on a hoist and the discs were skimmed and and new pads and 1 new wheel bearing front left . i hav jst replace the front right bottom arm with the bush that wears out in suter strut suspension but it hasnt stoped the noise but my car steers better but thats not the point. do i jst need so smear sum grease around sum places? my car hasnt gotn ne harder to steer and the power steering fluid hasnt droped at all. do i jst need to jack her up and hav a play see wat i can find
any ideas of wat this could be would be awsume
1991 gtz trueno "HELL YEA" 4 sale (sold and i miss it so)
event2
Postby keiichi » Tue Nov 09, 2004 12:18 am
cv maybe?
keiichi
Postby Ae92typeX » Tue Nov 09, 2004 10:09 am
probably wont do anything, but give it a soak with the hose- just to see if any of the bushes are real dry. I suspect if that the case it wouldnt just do it at that angle however.
If you do find where the noise is find out what the bush is made of first as some dont respond well long term to grease.
did you replace the bottom arm when you did the breaks or later?- if the same time id suspect it was that.
another small possibility could be if they took the parts off to skim the breaks and did not reassemble correctly e.g.- if they had to take of any suspension arms, some should be bolted up fully with a load on them, not free hanging.
yea, just afew 2c thoughts anyway
Ae92typeX
Postby 10k 20v » Tue Nov 09, 2004 6:29 pm
wheel bearing? have you checked to see if the hub nuts are tight?
10k 20v
Postby B1NZ » Tue Nov 09, 2004 9:04 pm
well my AE111 S/S was doing that until we replaced the fukked little piece of arm thats about 4 inches long on the front s/s Arms, doesnt do it now :wink:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby event2 » Tue Nov 09, 2004 10:21 pm
a nother thing it only does it on hot days. when its cold it dont do it. i did the s/s srm after the wheel bearing and breakes
event2
Users browsing this forum: Bing [Bot] and 19 guests
