Gear box strengthening
Postby B_giB » Tue Nov 09, 2004 12:38 am
is there a place that does it???
Does it exsist?
is it pricey???
for and AE101 GT Apex
nice and simple questions there 8)
Current: SXE10 Altezza
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby MrOizo » Tue Nov 09, 2004 9:57 am
why would you wanna do this? 8O
and you talking about the internals or the casing?
MrOizo
Toyspeed Legend
gear box
Postby shaggz » Tue Nov 09, 2004 2:36 pm
go to yuor local toyota repair placeask for trd synchros and cogs adn that will fix yuo up
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Postby Mr Revhead » Tue Nov 09, 2004 3:20 pm
TRD only go gearsets, not synchros etc.
you can get things worked on a bit, cryogenic freezing seems to be all the go at the moment.
why do you need yours strenghted? what are you using it for? i assume youll plenty of mods to need a strenghted box.
Postby MrOizo » Tue Nov 09, 2004 3:53 pm
Mr Revhead wrote: what are you using it for? i assume youll plenty of mods to need a strenghted box.
it's these 20v's putting out so much powah!
MrOizo
Toyspeed Legend
Postby Mr Revhead » Tue Nov 09, 2004 3:56 pm
well there is that :lol:
Postby atmosports » Tue Nov 09, 2004 5:24 pm
Strengthening for me would consist of getting the gears/shafts either cyro'd or shot peened if not both, only hassle is the cryo guy here in Auckland seems to be useless. Or else I'd do what I do with the race boxes & get them Isotropic finished which removes all the high spots etc like shotpeening but also reduces friction etc through a smoother surface finish. I'd then fit new synchro rings etc & if they are steel ones they'll need lapping, check them for fit etc. I also check for play in the shift linkages,detents etc & fix where possible.I would then rebuild with HEAVY DUTY bearings, Saeco & other bearing places will say you don't need heavy duty bearing but tell them to "Get F*cked" & fit them as they make a difference. Fit new gaskets etc & make sure you egt all the gears nicely on the bench before install. I would then recommend you use a straight mineral gear oil say a 85/90w this is waht Quaiffe & other sujggest for there dogbox & I've never had a problem with the likes of Valvoline/Pennzoil, the only synthetics to run are Motul/ or Mobil both of these have to be changed regularly like every race meeting. Do not use REDLINE yes you will gain power through reduced firction but you will $&#$% you g/box & it turns to jelly & is a pain to clean.
atmosports
Postby vvega » Tue Nov 09, 2004 5:27 pm
get a ze box and front hubs
problem solved
v
vvega
Postby Adamal » Tue Nov 09, 2004 7:27 pm
I don't understand the concept of cryogenic freezing, can someone please explain it to me? Ta
Postby atmosports » Tue Nov 09, 2004 8:22 pm
Basically the freeze the material dwon to a set level & keep it at this level for a set leng6th of time, roughly 4-6hours for some stuff. The structure of the material supposedly changes & refines the grain or something similar. Been a while since I saw all the tech stuff on it. We tried to get some stuff down by the guys here in Auckland but they didn't seem all that helpful. Supposed it reduces wear on brake rotors,cranks etc & lengthens there lifespan. A ot of the Nascar/drag guys in the states use it.
atmosports
Postby matt dunn » Tue Nov 09, 2004 10:21 pm
Yes box's can be strengthened.
You can get new gears sets made for them.
We had it done to a couple of W5* series boxes because the 1JZGTE would chew them out in three meetings. And you can choose your own ratio's
The setting up process is so expensive though. We had two sets made because it was not much dearer than one. The box is now behind a 700hp 2JZGTE. As for price, we had two made so it worked out about $2500 each. This was a few years ago when a s/h 6 speed supra box was $6000.
Postby atmosports » Wed Nov 10, 2004 5:56 pm
For an Ae101 Gt Apex you'd be looking at a C52 box, you can get a Quaiffe or TranX kit for them. Most people just swap in a Supercharged box. Else you could get Chalak of Pfitzner in Oz to make you a kit/gears. The only person in NZ I would get to make me a kit would be Geoff Bruce, think he calls himself Precision Engineering over the north shore, he makes a lot of 3,4 rotor shafts & has done gears for me previously. I know Charlie Evans in Hamilton does series 4/5rx7 strengthening & gearkits so you could talk to him.
atmosports
Postby B_giB » Wed Nov 10, 2004 8:45 pm
cheers for the help all :)
no mods on it as yet, but just for future refrence
B_giB
Users browsing this forum: Bing [Bot] and 18 guests
