t50 onto a 1jz-gte soarer
Postby MrOizo » Tue Nov 16, 2004 11:30 am
if you really want to run a manual behind the 1JZ (or either 1JZ or 2JZ engines) and you dont wanna fork out $2,000 for the R154 or apwards of $4,000 for the V160 (6 Speed) then i suggest you get hold of a big shaft W58 from a manual MKIV (JZA80) Supra. If from a Supra then you'ls already have the bellhousing, and have easier access to the right clutch kit combination.
Might wanna try finding all your other bits from a JZA80 Supra as i THINK the drivetrain are the same sizes.. a otherwise its a custom job. custom shafts are around about $600-900 depending a few things (length, universals, yokes etc.)
Another thing to look out for are the shifter positions from the boxes. Front, middle or rear shifters.
And as Drifter4ag suggested you wont really have much driving time with a T50 behind a 1JZGTE... i think even a 1JZGE you'ld be pushing your luck :?
MrOizo
Toyspeed Legend
Postby matt dunn » Tue Nov 16, 2004 10:34 pm
All_Fours wrote:why don't you just get a k50? Being cheaper, lighter, and easier to find, it would make it much easier for you to carry around spares and change them every 10km at the side of the road.
lol,
T50 and 1JZGTE do not match.
Even W55 aren't that flash behind a good one.
Our W55's used to last three events behind a 1JZGTE.
Postby Silent Knight » Tue Nov 16, 2004 11:05 pm
You'd crack a T50 backing out of your driveway :? :?
Like the others have said before.....easiest thing to do if you do not plan on pushin much more than 400hp is go for a W series box. 57/8 but the 58 would be best suited and get the rear mount shifter.
If you go upwards of 400hp then you'd want to luk at forking out the money for a R154 as they can handle everything you're going to be throwing at it.
If you really wanna the V160 way for the 6sp you'd be lukn at forking out about 4K jst for the box alone. And you will most probably need some modding in your tranny tunnel to fit one. This can be acomplished by using a hammer easy enough.
I would personally go for the R154 instead of the V160 but I won't go into why right now cuz i'll be going for weeks....(ask Mr Oizo why :twisted: )
Silent Knight
Postby 92GTApex » Wed Nov 17, 2004 12:38 pm
There is/was a V160 for sale on trademe, was asking $4750 with clutch etc
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby jamie kennard » Mon Nov 22, 2004 2:47 pm
hey guyz sry i mean a w58 on to 1jzgte lol
i give my wife a quarter inch at a time. for those 10 seconds or less im free
0211354229
jamie kennard
Postby MrOizo » Mon Nov 22, 2004 3:41 pm
jamie kennard wrote:hey guyz sry i mean a w58 on to 1jzgte lol
that sounds a little better...
would be best to get a W58 from a 2JZGE (non-turbo) as the've got the W58 (big shaft) on them.
Chances of finding the W58 JZ bell-housing on its own is pretty slim. But if you do it wouldnt make sense as it would prob be the same price as it with the bell housing.
MrOizo
Toyspeed Legend
Postby Mr Revhead » Mon Nov 22, 2004 4:15 pm
mr ozio.... your sig.... all class!! :lol:
Postby Drifter4ag » Mon Nov 22, 2004 10:32 pm
PM NITEB as he may have 1jz - W bellhousings available shortly
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
