Then you probably have the wrong two wires jumpered, or the connection isin't good enough between them, in that case, jumper them at the ecu end of things.
If that doesn't work, then chances are your ecu could be failing.
4agze engine light problems
Monsterbishi
- Toyspeed Member
- Contact:
Monsterbishi
- Toyspeed Member
- Contact:
ok, what is your car, AE92, AW11? All that essentially needs to be done is trace the two diag wires back to the ecu and jumper them there, although you could start out by taking out your ecu, unscerwing it's lid and examing it for any leaking caps, etc.
If it's a AW11, I could probably meet up with you and you could try out my AFM ECU in your car to see if it does the same thing, I've got a MAP AE92 SC one around here somewhere...
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
- Toyspeed Member
- Contact:
