SW20 Smoking at 4-5,000 Revs
Postby vvega » Fri Dec 31, 2004 1:21 pm
sounds like its running ritch
sounds normal
v
vvega
Postby vvega » Fri Dec 31, 2004 2:01 pm
BZG Wagon wrote:Black smoke = Running too ritch
Grey smoke = Running Rich & burning oil
Blue smoke - Burning Oil
grey can also be the type of fuel you run
vvega
Postby Chickenman » Fri Dec 31, 2004 2:04 pm
Cos we have some utter garbage fuel in NZ.... water in the tanks etc...
Have you changed servos lately?
It does sound mildly normal though.
Baby Jesus
Chickenman
I Am The Walrus!
Postby Rasker » Wed Jan 05, 2005 12:41 pm
I had changed to Mobile in the last two months, can't recall seeing it before then. I'll give the BP fuel another go, failing that its due for a warrant this weekend, might get the mechanic to do a few tests, here's hoping it is a simple fuel issue this car is getting expensive :(
Rasker
Postby Heylin » Fri Jan 14, 2005 10:03 pm
Is it a Turbo ?, perhaps it could be turbo "blow by". Other thing to check perhaps would be the Dizzy, HT Leads and Plugs, not getting a complete burn of fuel at higher revs mabey.
Just a thought.
Heylin
Heylin
