mr2 gearbox?
mr2 gearbox?
Postby 3T-Rona » Fri Dec 31, 2004 12:55 pm
is an mr2 box just a fwd box backwards?
can a fwd gze lsd be used?
3T-Rona
Postby vvega » Fri Dec 31, 2004 4:41 pm
so you have a sc ??
and why do you want to change gearboxes ???
im not understanding what your tring to do ??
v
vvega
Postby Mr Revhead » Fri Dec 31, 2004 5:24 pm
i suspect hes trying to get an lsd in his car..
as is wanting to know if an ae101 gtz box will fit......
Postby vvega » Fri Dec 31, 2004 5:34 pm
arrrr
well then your out of luck :D
you need diffrent longer spline for lsd to work
and unless you can find a early sw20 turbo one or a aw11 sc manuel lsd your buggared
auto shafts are diffrent to manuel ones as well :D
just by the trd lsd and get on with life
trust me it will be easiest
v
vvega
Postby celica_tommo » Sat Jan 01, 2005 2:47 am
yeah... I encountered these sors of problems trying to adapt an LSD gearbox from a Curren to my earlier Celica. Wishful thinking said that everything 'should' match up but in practice there are issues that although they can be overcome with $$$ are not worth the time or money just to have an LSD gearbox
celica_tommo
Postby 3T-Rona » Sat Jan 01, 2005 10:16 am
lol sorry for the confusion, i dont have an mr2, i was just weighing up the differences between an aw11 sc (converted to turbo) or an sw20 turbo. they look like fun lil cars and if i could find one cheap enough i wouldnt mind getting one.
3T-Rona
