4agte in starlet, any one done it?
Postby kingcorolla » Wed Dec 29, 2004 6:00 pm
well fwd water pipes, theres one main pipe down the block, which attaches to the thermostat, and the other pipe on block, is hot water return, and is plumbed the same.
Rwd have an outlet on the head (also) and the inlet on the waterpump.
the two pipes on the block (rwd), are for heater return, and hot feed for throttle body, as well as a return from the throttle.
the sensor block on the back of the head, is used for hot heater feed, and also hot throttle feed.
1983 Carina AA63 4age
kingcorolla
Postby terrytuffguy » Wed Dec 29, 2004 6:08 pm
well I hope you know what your getting yourself into...........
Anyway the pipe that runs behind the waterpump runs to the bottom of the radiator as it's the return line. There is another main pipe that comes out under the left cam pulley and above the waterpump, this runs into the top of the radiator oviously. Easy as.......until you need to deal with two hoses that run out of the head, they circulate water through the thermostat housing that runs in series with the bottom hose.
It's best to look how it all works on a 4ag levin or fxgt corolla, I'm asuming this is a fwd 4ag.
My 4AG powered starlet puts out 227rwkw & 12.39 @ 115mph........ YEA RIGHT, Tui.
terrytuffguy
Re: 4agte in starlet, any one done it?
Postby kingcorolla » Wed Dec 29, 2004 6:54 pm
3T-Rona wrote:i spose its goes with any rwd 4agte,
dunno if you have fwd water pipes ore not, the ones in my pic are rwd.
kingcorolla
Postby Al » Wed Dec 29, 2004 8:04 pm
afaik thats terrytuffguy's :wink:
Al
Postby 3T-Rona » Thu Dec 30, 2004 1:46 pm
any one no if the tin plate that goes between the block and the g.box is compatible from a fwd, this is for a rwd t-50.....
also kingcorolla, the pic u posted before didnt show up.
3T-Rona
Postby dohca » Sat Jan 01, 2005 12:02 pm
terrytuffguy wrote:lol, do you like my rangi bonnet stand?
who made your manifold?
dohca
Postby 3T-Rona » Sat Jan 01, 2005 3:31 pm
hahaha nice
got the pipes of the aw11 i was talkin bout before, still short one tho, the smaller pipe that comes off the top radiator pipe, runs water to the plenum i think, need the lil pipe as i can use it for my turbo (water + oil cooled)
3T-Rona
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
