4A-GE valve stem seals
Postby AE85.6 » Tue Jan 04, 2005 12:27 pm
hmm ye valve stem seals i think, my AE92 levin used to do that exact same thing, only ever blew smoke on some starts never when reving or anything just everynow and then first start after it had been sitting and it would puff a little bit of blue/white smoke.
im pretty sure ive read a topic that started overing it but i think it was quite old so you might have to do a search if not thou someone will be able to tell you the details,
i did notice thou on my old levin it did it more often if the oil was shyte so i used to change it a bit more often too, i guess as the oil turns crap and looses it viscousity properties or thins out more it must seap through a bit easier
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby Dr-X » Tue Jan 04, 2005 12:44 pm
Yep definately sounds like stem seals. My car does the same (3sfe). Nothing to worry about really, definately not worth the money to repalce them.
Dr-X
Postby demis » Tue Jan 04, 2005 1:33 pm
you have to take the head off to replace them dont you???
EX 1984 Corolla FX GT (AE82) 1st gen 4age
EX 1996 Corolla BZ touring (AE101) 5th gen 4age -LSD
EX 1997 Carib Z touring (AE111) some 4afe muck
Ex 2000 Fielder S (ZZE122)- Its BIG RED
2002 Corolla Ts (ZZE122) Mr ~ Ts
demis
Postby jjd » Tue Jan 04, 2005 3:21 pm
demis wrote:you have to take the head off to replace them
:lol: no you dont.
jjd
Postby vvega » Tue Jan 04, 2005 5:48 pm
normall you do have to take the head off
you can do it without but it requires some very specaillized tools
or a whole lot of patiance
you need to take the valve spring out and replace a seal that presses onto the valve guide itself
then reasemble the spring/retainer asemebly and put the cams bak in and your done :D
its not hard
v
vvega
Postby CAMB01 » Tue Jan 04, 2005 7:40 pm
If you do it in place make sure you have the piston at TDC on the cylinder your doing. Otherwise you'll have to pull the head off as the valve will fall into the cylinder.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby vvega » Tue Jan 04, 2005 7:57 pm
or you can presurise the cylander and use the specail tool :D
v
vvega
Postby gordon77 » Wed Jan 05, 2005 9:23 am
would this special tool be specific to toyotas?
What is RR?
gordon77
Postby Monsterbishi » Wed Jan 05, 2005 9:51 am
It is for the 4AGE, due to the layout of the head.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
