Mr Revhead wrote:if your still in doubt, post up the model and frame numbers.
in fact go the whole hog and post up colours codes etc as well.
then i can confirm exactly what model you have etc
Stinger wrote:What can you tell from these numbers
Model: E-ST185H-BLMVZ
Engine: 3S-GTE
Frame no: ST185-0022048
Color/Trim: 202 FQ10
Trans/Axel: E150F - 734
Plant/Built: A54
Its a 92 Widebody, has the twin entry turbo ceramics power on the IC. Does it have the RC transmission?
_will_ wrote:Sorry as well, but im going to have to put a stocking over my head and do a bit of hijacking myself...
Where abouts on the car can i find the model code? I didnt realise that Group A and RC were different.......![]()
Ta!
DeeCee wrote:Thanks 2L. Had a drive on the motorway and its running very smooth. Had it up to 160 and found it needed a wheel balance, but the turbo and engine are running very smoothly.
I'll talk with the owner about what the car is and see if i can get the price down a bit.
Thanks to everyone for the help.
Dave
BR0Z wrote:Hi just my 2cents worth.
I thought to export version of the JDM RC was the Groupe A not Group A, the export version to NZ & Australia also had the 260kph speedo.
Cheers, Mark
Return to Technical FAQs - General
