4age 20v silver top ECU
Postby SONY » Tue Jan 11, 2005 10:58 pm
i am going to fit a 20v to my ae92 levin ,,the engine is from an automatic ae101 levin(1992),,
so i need an manaul ecu for the engine~~~
are all the silver top 20v using the same ECU??
second hand companys offer it for about$230
as i see many guys use"LINK ECU"for their 20v,,i just wanna know can i have a link ecu for my car instead of the stock ecu??and how much is that?~~
thanks a lot~~
SONY
Postby Mr Revhead » Wed Jan 12, 2005 12:04 am
you can use the auto ecu
just have to wire the neutral switch shut
Postby spencer » Wed Jan 12, 2005 1:30 pm
I gotta manual ecu if your interested
ms63 crown
spencer
Postby 85AW20v » Wed Jan 12, 2005 3:59 pm
If you've got the auto loom with it, do what Mr Revhead says as the plugs are different on the auto and manual ECU's so you need the manual loom to match.
See ya
Simon
85 MR2 20v
85AW20v
zz
Postby SONY » Wed Jan 12, 2005 11:25 pm
thanks you guys so much
i have the auto ecu & loom
...looming is really a pain for me..there are wires everywhere... 3 terminals come out from the ecu...2 of them go to the front(injector ,fuse box,sensors,,meters...),the other one comes into the inner wire assembly...i am so screwed...anyone has some suggestion for me...i am such a new guy...
SONY
Postby Mr Revhead » Wed Jan 12, 2005 11:37 pm
it maybe an idea to get some one to help you with it....
re the neutral switch..... how about wiring it to a switch hidden in the cabin somewhere? cheap imobiliser :wink:
