Garrett t3 q?
Garrett t3 q?
Postby 3T-Rona » Thu Jan 13, 2005 6:44 pm
any one actually have a garret t3, i need help on the oil feed problem, i no (have been told) that the oil feed is restricted but to get a factory restrictor of a skumline from the wreckers it will cost a lil to much, so any one hav a picture or can tell me the measurement of the restricter, i was thinkin of just using sum of that shitty copper pipe u get with TRISCO gauges for my oil feed.... would that be restrictive enuf or too restrictive?
help please anyone
Joseph
3T-Rona
Postby mike86ze » Thu Jan 13, 2005 8:21 pm
2mm is usually enough on a 4age.
dont know if the oil presure is much different on a 3t.
mike86ze
Postby JamesM » Thu Jan 13, 2005 9:57 pm
you could just weld up the banjo bolt and then drill it out to the 2mm
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby 1598cc » Thu Jan 13, 2005 10:03 pm
just getta oil presssure guage and see what psi it goes to.. if it aint anything under 65psi then your sweet as.. otherwise a restrictor is nessasary
1598cc
Postby 3T-Rona » Fri Jan 14, 2005 6:07 pm
so it should be restricted to below 65psi, cool cheers guys.
3T-Rona
