Should a valve move side to side at all when it is lifted out of its seat any amount?
Mine are moving less than 1mm, and all the ones I have taken off seem to move about the same amount.
The valve springs and all that stuff has been removed.
ATAl wrote:Should a valve move side to side at all when it is lifted out of its seat any amount?
fivebob wrote:Guesstimates made using the eyecrometer are usually a complete waste of time unless something so far out of spec it's really noticable. The tolereances are very fine and need to be measured with the correct equipment.
