ae101 fxgt buying tips??
Postby redline racer » Tue Jan 25, 2005 8:30 pm
Looking at buying a ae101 1992 fxgt. Is there any common problems with this model i should look for?
redline racer
Postby Dell'Orto » Tue Jan 25, 2005 8:53 pm
Just the superstrut, if it has it. Otherwise they're a good solid Toyota :D
Postby Twolitre » Tue Jan 25, 2005 8:59 pm
Lack of engine power? :wink:
Just kidding, gearbox synchros will be worn on thrashed, higher K's models, check oil to see if it's clean and correct level, same with coolant.
Ask owner for any receipts for things such as cambelts and routine servicing.
Twolitre
Postby redline racer » Tue Jan 25, 2005 9:40 pm
Forgive my ignorance but how can i identify wether it is superstrut or not? (other than the sticker on the side :lol: )
redline racer
Postby Dell'Orto » Wed Jan 26, 2005 1:21 am
The flares on the wheel arches ;) Bigger brakes than non SS too
Postby Twolitre » Wed Jan 26, 2005 1:38 am
Superstrut will look like whats in the pic below.
I'm not sure if you're familiar with conventional McPherson strut but super strut is fairly similar with an extra link and control arm, don't let it put you off though as it does help the car handle very nicely and if you need replacement parts Mr Revhead can do good deals on genuine Toyota replacement parts.
Twolitre
Postby aesc » Wed Jan 26, 2005 9:20 am
Also another explanation of Super Strut
http://www.geocities.com/fxgt20/
I think this is GT Girl's site, some good info on 101 fxgts there
EX AE101 owner
2013 Ford Focus ST
aesc
Postby 20v FX-GT » Wed Jan 26, 2005 2:19 pm
aesc wrote:Also another explanation of Super Strut
Hey, I made that site - GT Girls car though.
Another thing to look at when buying a 101 FX (and any 20v) is the VVT pulley - if its done over 140kms chances are it needs replacing - you will be able to hear it.
1981 & 1982 MK1 VW Golf GTI 8v
1997 AE111 Toyota Trueno 6 Speed
My profile l AE101 FX GT Site l AE111 BZ Site l
20v FX-GT
Postby Mr Revhead » Wed Jan 26, 2005 2:26 pm
yup the vvt pulley can make some noise... but its best to test it.. a lto off ppl reckon their car has a stuffed pulley when in fact its another noise....
they arent too bad to replace though, certainly not as dear as the blacktop ones.
they wont harm the engine at all, but they can jam in one position and lose power/drivibility
Postby CozmoNz » Wed Jan 26, 2005 2:39 pm
Mr Revhead wrote:yup the vvt pulley can make some noise... but its best to test it.. a lto off ppl reckon their car has a stuffed pulley when in fact its another noise....
HAHA, EXCACTLY! found out what it is then!! thanks revhead ^_^
Rayne For President!
CozmoNz
Postby redline racer » Wed Jan 26, 2005 8:35 pm
Cheers for the info.
What sort of noise does a worn vvt pulley make?
redline racer
Postby Mr Revhead » Wed Jan 26, 2005 10:06 pm
dunno, never heard one in person.
have seen the test procedure etc some where... ill see if i can find it
Postby Mr Revhead » Wed Jan 26, 2005 10:16 pm
found the vid
http://www.rollamods.com/video.htm
test is to apply 12v to the pulley
if noise stops, its the pulley :wink:
cheers to the legned that is rollamods :wink:
Postby Dell'Orto » Thu Jan 27, 2005 12:11 am
redline racer wrote:Cheers for the info.
Like a very quick rattly noise at startup if it isnt too rooted, but a constant tappetty kind of noise if its totally stuffed.
Postby GTCRSHR » Thu Jan 27, 2005 8:51 am
i get that sorta noise
Nothing to see here ...
GTCRSHR
Postby 20v FX-GT » Thu Jan 27, 2005 12:04 pm
Mr Revhead wrote:they arent too bad to replace though, certainly not as dear as the blacktop ones.
I thought the blacktop ones were cheaper - what prices are we talking?
20v FX-GT
Postby 20v FX-GT » Thu Jan 27, 2005 12:11 pm
I'd say more like the other way around. Its pretty normal for them to make a slight tapping noise when the engine is warmed up. If it does it on startup it means that the fluid has leaked out of it while sitting and there is no fluid it in until oil pressure builds up - it shouldn't have to rely on oil pressure. If it can't hold the fluid it will rattle more and more.
20v FX-GT
Postby Dell'Orto » Thu Jan 27, 2005 4:39 pm
I dont know, the few that I've heard have done that? Heh, maybe the one I thought was stuffed wasnt as bad after all :D
Postby CozmoNz » Thu Jan 27, 2005 4:58 pm
mine seems to be very annoying @ idle... tick tick tick tick etc
but i gotta reset my tps :D so, it might just be normel and im thinking my vvt is playing up.
pretty sure its working though... pulls hard throughout the entire revrange, no *waiting for power up high* or *good amount of pull down low, no high end* etc.
well, this from a 20v perceptive :P no 3sge boys going *what! torque! a 1.6 has no torque!*
CozmoNz
Postby redline racer » Thu Jan 27, 2005 7:31 pm
Cheers guys thanks 4 all the info 8)
redline racer
