kingcorolla wrote:if this is for your 4age, you cant take the belt off, otherwise your waterpump wont get drive.
kingcorolla wrote:if you disconnect the main power lead, (not the plug), it should shut-off charge.
as you are putting power into turning that pulley.
Stealer Of Souls wrote:I wrote:if this is for your 4age, you cant take the belt off, otherwise your waterpump wont get drive.
Electric water pump.... so I don't need to drive it anyway...
Dr-X wrote:Removing the belt is very simple, you just need a shorter belt. A lot of people here dont seem to think about little things like that.
Users browsing this forum: No registered users and 57 guests
