toyota 4age carb convertion
Postby nickmidy » Thu Jan 20, 2005 8:49 am
I'm putting side drafts on my AE82(blue top) and i need a distributor that has vacum advance.
does anyone know where to get one, what one to use?
any help would be great
thanks
nickmidy
Postby dxtawagon » Thu Jan 27, 2005 4:46 pm
i have one with a vacuum advance that i used on my bluetop 4age running carbs. not sure where it came from but was on the setup when i got it.
i sold the dizzy to someone over trademe but havnt heard from them lately so might be possible to sell to you if he doesnt contact me.
whats it worth to you??
its in average cond leaks small amount of oil into cap sometimes, as it sticks out horizontal
dxtawagon
Postby Gx71man » Thu Jan 27, 2005 8:42 pm
the shitti old ae80s(i think) the corolla lifts had 4as in them with a single carbi. soch dunno if it will fit though
I Give My Mrs A 1/4 inch at a time, For those ten seconds or less Im Free...
Gx71man
Postby matt dunn » Thu Jan 27, 2005 10:23 pm
Gx71man wrote:the shitti old ae80s(i think) the corolla lifts had 4as in them with a single carbi. soch dunno if it will fit though
Wont fit.
Most common thing i've seen is a electronic 4K dist modified to fit.
Matt
Postby fangsport » Thu Jan 27, 2005 10:30 pm
why do you want vacuum advance?
it isn't necessary.
fangsport
Postby Dragger_Dan » Fri Jan 28, 2005 8:50 am
http://www.trademe.co.nz/Trade-Me-Motor ... 427046.htm
I've seen this thing here heaps... take a look. SOunds like just what you need.
Dragger_Dan
Postby matt dunn » Fri Jan 28, 2005 12:29 pm
fangsport wrote:why do you want vacuum advance?
it isn't necessary.
Correct, but mechanical advance is.
Postby suberimakuri » Fri Jan 28, 2005 6:25 pm
why not run factory ecu for spark?
2 4ages are running that at present, both megasquirt for fuel only (1x NA/quads, 1x turbo).
my 3sge runs stock ecu for spark and MS for fuel.
suberimakuri
Postby Dragger_Dan » Fri Jan 28, 2005 8:38 pm
Karl_Skewes wrote:why not run factory ecu for spark?
Does anybody know much about megasquirt here? I'd be interested in investigating further... how hard is it to get the parts and assemble them?
Dragger_Dan
Postby suberimakuri » Sat Jan 29, 2005 10:05 am
www.megasquirt.info
www.msefi.com
read my previous post.
suberimakuri
Postby Peradx » Sat Jan 29, 2005 9:37 pm
Try this, I have a redtop 4age running su carbs. Apart from a small fueling problem the car runs fine.
What I did to solve the spark problem was this. I brought a 3K dizzy, had the gears removed from both the 3k and the 4a, then had the hole for gear from the 4a enlarger to fit the shaft from the 3k. Nexted had the oil pick up removed from the 3k shaft, now both shafts should be the same lenght. The last thing to do is make a sleve that has an o ring on the out side of the sleve so that now the part of the shaft that slides into the head are the same.
Peradx
Postby Drifter4ag » Sun Jan 30, 2005 11:30 am
How bout this then
leave the wiring loom in there as is
install the carbs
set the fuel lines and pumps up etc
cut the plugs from the map sensor
cut the plugs from the tps
cut the plugs from the injectors
leave the water temp plugs intact
crank it over and you will see that it runs and advances fine .. i dont understand why anyone would goto a 4k dizzy when the standard setup works fine.
And yes.. visit the Megasquirt forums and website and check it out .. its fantastic ..
Karl Skewes knows quite mucho about MS but before asking any questions I request that you go have a good read on the forum :)
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Users browsing this forum: Bing [Bot], Google [Bot] and 17 guests
