4age not running, no spark *help*
Postby AE85.6 » Wed Feb 02, 2005 1:55 pm
ok dropped the girl at the sparky today so as long as they get time to look today i should hopefully find out what it is and let ya know,
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby AE85.6 » Wed Feb 09, 2005 5:54 pm
picked up AE from sparky today and got it home just, after $&#$% around for about a week now it has spark sadly it just started to spark so they dont know what they did to get the spark back so i guess it could go again.
both sparkies and mechanics have been working on it now, the mechanic has set the timming and which is only just ok on idle, however when reved the timing retards instead of advancing ??? WTF its like the rotor is now spinning the wrong way or something ? and he also said he swapped the lead order onto the distributor cap ? i thought this was weird considering there should not be anything wrong with how it was unless now that its retarding instead of advancing he has swapped the leads to reverse aswell ???
anyone got any ideas ? mite try swapping the computer as thats the only thing i havnt done then try redoing timing and ignition order otherwise im back to square one.
AE85.6
Postby AE85.6 » Fri Feb 11, 2005 1:32 pm
bump
AE85.6
Postby JamesM » Sat Feb 12, 2005 12:39 am
i woudl put the leads back as normal.. and sort out what it is doing.. the rotor wont be spinning backwards haha... if u need a computer to borrow i have a spare one. maybe u have fault ignitor,, bad connectiosn in dizzy?
Team Megasquirt
1984 AE86
180kW, 600Nm@wheels @ 16.5psi
JamesM
Postby AE85.6 » Mon Feb 14, 2005 2:12 pm
sweet as man ill try correct a few things over the next day or so and let ya know,
AE85.6
