Sandard toyota vs TRD Head gasket
Postby Rick » Tue Feb 01, 2005 7:39 pm
I am in the process of rebuilding my small port 4A-GE for my AE-85 racecar and I have been looking at the different sizes available, TRD head gaskets come in 0.8 and 0.5mm. Can anyone tell me the pros and/or cons of the different sizes, is there is an advantage going for the smaller one?? Or should I stick with the standard size??
Postby CozmoNz » Tue Feb 01, 2005 8:09 pm
Pros.... Increases Compression ratio
Cons... Its Trd..... get ur cash ready :P.
Rayne For President!
CozmoNz
Postby ChaosAD » Tue Feb 01, 2005 8:09 pm
There is nothing wrong with the standard genuine headgasket, the different sizes are to fine tune the compression ratio and also give a bit more quench/squish.
TRD prices are a lot better than they used to be, my .8mm TRD headgasket set me back $99 but that was a pretty good deal.
ChaosAD
Postby Rick » Tue Feb 01, 2005 8:37 pm
ChaosAD wrote:There is nothing wrong with the standard genuine headgasket, the different sizes are to fine tune the compression ratio and also give a bit more quench/squish.
Why did you go for the .8mm over the .5mm??
Postby Adamal » Wed Feb 02, 2005 8:12 am
The problem with increasing the compression ratio is that you will require a higher octane fuel for it to run properly. It will start to ping otherwise.
An .8mm would give less compression than a .5mm. With a .5mm, you'd probably want to run 98 octane and probably chuck in some octane boost as well. Of course, the compression depends a lot on the pistons etc, but the gasket makes the subtle differences.
Postby Mr Revhead » Wed Feb 02, 2005 5:56 pm
the stock gasket is 1.2mm
you will need to do some maths to work out the ratio change, i dont think its a seriosu amount...
prices of these gaskets has come down a lot lately. under
$100 now.
the TRD one is also a metal one and will take a bit more than the stock one, however the stock one is plenty strong enough for most applications.
Postby MetalupYoAss » Wed Feb 02, 2005 8:45 pm
i looked at this a while ago for my bluetop turbo.. i went with standard thickness toyota one as i dont want to increase compression, if you were na tuning it though you could use the TRD ones to get a bit more performance.. i think the .5mm one only increases compression to around 9.9:1 which is still less than standard 20V compression..
MetalupYoAss
Postby TRD Man » Wed Feb 02, 2005 9:28 pm
Actually, the std gasket used to be 1.0mm. I'd be surprised if this has changed.
We almost always recommend & sell the 0.8mm TRD gasket which we always keep in stock here in Wellington. Using the 0.5mm gasket can require the valve pockets to be machined to avoid contact.
As Warwick has stated, the application of a TRD gasket raises the compression ratio by so little fuel octane is not an issue.
TRD Man
Postby Mr Revhead » Thu Feb 03, 2005 7:58 am
no stock 4age/4agze 16v gasket is 1.25mm when torqued to spec
Postby suberimakuri » Thu Feb 03, 2005 8:41 am
as i understand it the change to small port brought about a change from 1 to 1.2mm
i don't know about redtop tvis.
adaml, you will not ping just by changing gasket, it will just run a couple of points leaner... but nothing to worry about.
most people don't even max the timing on their motors either.
metal gasket is nice for reuseability.
$100 is cheap...
BR900 from Appco is about half that. And is the 1.2mm gasket we used on the turbo motors. But if I was building NA motor I'd just get TRD gasket.
If the head and block are good, then 0.5mm is what i'd get. Can always deck head a little so you're sure it'll seal.
suberimakuri
Postby Mr Revhead » Thu Feb 03, 2005 10:02 am
there is a supersession in the the ae82 gasket to the same number as used in the ae92 onwards 16v, the same gasket is used in the 4agzes aswell. its not a change, but a supersession. it has nothing to do with the big port/small port change. the size for that gasket is 1.25mm
Postby Chickenman » Thu Feb 03, 2005 10:24 am
Mr Revhead wrote:supersession
Too many of those and you'll get fired 8O
Baby Jesus
Chickenman
I Am The Walrus!
Postby suberimakuri » Thu Feb 03, 2005 10:34 am
hmm.. i'll have to check acl listings again.
suberimakuri
Postby Mr Revhead » Thu Feb 03, 2005 10:45 am
just a clarification....
ae82 and early aw11 gasket is a different part number, in 9th 87 the aw11 changes to the 42mm crank and the gasket number changes to the later gasket number, for the ae82 and early aw11 it lists a different number which supercedes to the later one
Postby ChaosAD » Mon Mar 28, 2005 5:15 pm
TRD Man wrote:Actually, the std gasket used to be 1.0mm. I'd be surprised if this has changed.
How much can you take off the head if using a .8mm H/G?
ChaosAD
Postby RedMist » Mon Mar 28, 2005 8:07 pm
I've always planed a standard amount from all my heads, wither or not I ran high compression pistons, standard or 310 degree 11mm lift cams, had an additional headwork or ran fuel from 91 to methanol.
from here..................................... to here.... or was that here?
Can't remember if I measured it imperial or metric.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby ChaosAD » Sun Apr 03, 2005 3:44 pm
I just put a .8mm head gasket on a bluetop, minimum taken off the head and set the base timing to 10 deg.
Would it be fine to run on 91? or should I run 96 and advance the timing a bit?
I would expect 91 would be fine as I've heard the bluetops are designed to run on 89.
Just out of interest, what would one expect to pay to have a blown headgasket replaced on a bluetop by a mechanic?
ChaosAD
Postby Mr Revhead » Mon Apr 04, 2005 12:54 am
89?? hell no
go 96
Postby ChaosAD » Tue Apr 05, 2005 8:35 pm
I mean 89 octane when STANDARD.
So would 96 give any benefit over 91 octane with the 10 degrees base timing?
ChaosAD
Postby Mr Revhead » Tue Apr 05, 2005 11:04 pm
i mean it would not have been made to run on 89 standard....
maybe ethiopia spec ones maybe.....
id think 96 would be ok on 10deg. is this the one with the TRD gasket and planed block/head?
