AE101 FXGT - 4AGE or not?
Postby pinkcandyfloss » Fri Feb 04, 2005 10:44 am
Hello, forgive my ignorance but we are in the process of buying an ae101 FXGT.
I have just paid $25 for a vehicle check and the engine number is
4A-K392655. I was expecting to see 4a-GExxxxx!?!
I have an ealier model fxgt the ae82 and believed that the 4age was a feature in all the later models too.
Did the engine change or are we being duped and getting a standard corolla that looks like a fx? We are not seeing the car till tomorow when we are picking it up from Taupo.
Please help
pinkcandyfloss
Postby Distrb » Fri Feb 04, 2005 10:47 am
AFAIK there are 2 engine types that grace the Ae101 shell... 4age found in the Fx-Gt, and the other which i believe to be a 4afe, which resides in whats commonly stickered as the Fx-Sj
easiest way to seperate the two by looking at them, the fx-gt has all round discs where as the SJ has drums on the rear, also the gt has the twin exhaust from factory, where as the sj has a single with the muffler sitting on the drivers side... (exhaust style may be not a good indicator if its been fitted with an aftermarket system)
I know that in the Ae82 & Ae92 shapes they made something similar to the 101 Fx-Sj that was badged as an Fx-G
hope that helps in some way
Distrb
Regular Poster
Postby pc » Fri Feb 04, 2005 11:42 am
If the engine has been changed to a 4a-ge you might want to make sure that the suspension & brakes have also been changed. Also if the engine is different than the chassis plate says, you will probably need a cert. (just if you want to be legal to the letter of the law :)
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby ee904age » Fri Feb 04, 2005 12:35 pm
Quite often the number on documentation shows the number which is stamped on the block. All 4AGE's will have 4A-****** on the block as that is the engine number not the engine code. Id be 99% sure if its an FXGT as said, it will be a 4AGE.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Mr Revhead » Fri Feb 04, 2005 12:55 pm
the engine number wont tell you the engine type
you need to look on the build plate
thats the silver tag on the fire wall (not the vtnz one)
it will have model numbers etc on it
under the engien it will have the engine number and code.
it will tell you there what engine it has.
model number for an auto fkgt is ae101-agpvf manual is ae101-agmvf
Postby Dodgy Guy » Fri Feb 04, 2005 2:34 pm
if its an ae 101 wont the cam cover be silver? or black? i could be wrong......
Dodgy Guy
Postby Mr Revhead » Fri Feb 04, 2005 2:42 pm
yes itll be silver... when it left the factory, and 4afe has silver cam cover as well
Postby Dodgy Guy » Fri Feb 04, 2005 2:43 pm
oh ok my bad :oops:
Dodgy Guy
Postby CAMB01 » Mon Feb 07, 2005 10:41 pm
Heya Distrb, is that all your AE82 does down the quarter 16.6, with those mods, i don't mean to sound like an ass but that is pretty slow for an AE82.
My AE92 in full street trim (sounds, mags) does a 16.5 @ 83.7mph.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Distrb » Tue Feb 08, 2005 9:42 am
CAMB01 wrote:Heya Distrb, is that all your AE82 does down the quarter 16.6, with those mods, i don't mean to sound like an ass but that is pretty slow for an AE82.
thanks for pointing out the blatantly obvious
what mods are you talking about? it is bog stock apart from a lightened factory flywheel, whilst we're declaring the state of play, take this into account....
- full street trim (sounds/mags)
- removed t-vis
- F**ked second gear
i know that you understand what its like driving one of these things without t-vis. im currently toying with the idea of putting t-vis back in to see if it makes any difference to the times. im picking it wont and i just need more time on the strip, but others think it'll make a huge difference.
times will drop with practice, i mean i've had 2 runs on the strip with that car, nobody is a whizzkid straight out of the box, give me some more track time and it'll get better.... theres scope for at least a 15.9 with this setup...
i would ask you to take your ae82 to the track and have a go to make a real comparison and see what you can do with it, but i'll pick that by the time the next meet rolls around it'll be far from standard? so that wouldnt really be a fair comparison
Distrb
Regular Poster
Postby Mr Revhead » Tue Feb 08, 2005 10:16 am
16.6 for an old fxgt that cost 2 fifths of f**k all.....
and only a coupla runs.... id be happy with that.
hell the shot of it leaving the caldina behind on the line is worth the cost of the car to me!! :lol: :lol:
Postby Distrb » Tue Feb 08, 2005 10:36 am
Mr Revhead wrote:16.6 for an old fxgt that cost 2 fifths of f**k all.....
exactly my point.. lol, im not complaining in the slightest.. i mean how could you when you paid $50 for the car in question...
:lol: :lol: :lol:
at the end of the day, im just trying to be realistic with respect to the combination of the car, the minimal mods done, the weight and experience of the driver :oops: and track conditions...
Distrb
Regular Poster
