Glanza V no more boost :(
Postby Akane » Sun Feb 13, 2005 4:41 am
Mum was driving her car, she said all of a sudden there's a lost of power, so I took it for a spin and surely there were no more boost, apart from that I don't notice anything different, I heard the Glanza V's uses the CT9A which is a steel turbine, so I guess these don't fall apart etc. The pipings are all good, I checked the wastegate, I can pull it open with a vice grip, although not a lot of force needed but again these turbo's are tiny, and I don't know how stiff the stock standard wastegate springs are.
Anybody have any clues? no boost gauge but the LED display on the dash board don't come up, the "LO" button is not selected.
Postby Elmendorf » Sun Feb 13, 2005 10:10 am
First off the Glanza run the CT9b, only difference between the CT9a and b is an extra fin on the compressor wheel due to the extra fat the Glanza has.
Have you checked the vaccum hose and the oil feed lines?
Also check the manifold for any cracks as like their predicessor they arent the best design and tend to crack.
Elmendorf
Postby Akane » Sun Feb 13, 2005 4:03 pm
I have checked all the lines that I can see, but I can't see the oil line, I've checked the manifold they all seems fine, although I can open the wastegate with my finger, although with a bit of force, would this be the problem?
There's absolutely no boost, not even 1 pound I think, could the turbo seize or the wastegate packed a sad?
Postby Akane » Sun Feb 13, 2005 4:22 pm
I have just hooked up a boost gauge and drove the car, as the revs climb, the needles goes back to vaccume slowly, as if there was some restriction.
Postby vvega » Sun Feb 13, 2005 5:52 pm
lol you jave no luck with turbos now do you
sounds like it seized to me
dose it make any turbo like nosies ??
you know wizz wizz ??
v
vvega
Postby CAMB01 » Sun Feb 13, 2005 6:52 pm
check theres no holes in your intercooler, you could be losing boost through it.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Akane » Mon Feb 14, 2005 2:25 am
absolutely no luck, this is a non-modified Glanza V, sigh.
i checked all visiable leaks, i mean if there's a leak there should still be SOME boost, there is NO BOOST in this.
could these things seize easily? common problem?
Postby GT4 20 » Mon Feb 14, 2005 7:40 am
Does the turbo still spin? Remove the intake pipe so you can access the turbine wheel. See if still spins freely.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Akane » Mon Feb 14, 2005 5:26 pm
the turbo is pretty tight, and looks like it's hidden behind the power steering pump, i'll look into removing that.
Postby Akane » Mon Apr 18, 2005 4:02 am
The turbo's seized. LOL
Postby Bling » Mon Apr 18, 2005 6:45 pm
gutted :( at least you got to the bottom of the problem :x
Postby Lunchie » Mon Apr 18, 2005 8:18 pm
BZG|Bling wrote:gutted :( at least you got to the bottom of the problem :x
wack a tdo5 on it shell be sweet as :D
"The air is heavy with antisipation as cozmo revs, drops the clutch and...... stalls with the hand brake on"........ "cozmo's hand brake one, cozmo 0"
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1201 <----Click to see real POWER :P
Lunchie
Postby Santa'sBoostinSleigh » Mon Apr 18, 2005 9:39 pm
ya mum musta been doin too many launchies :P
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Akane » Mon Apr 18, 2005 11:29 pm
she got a stock replacement, don't want all that break down and get it fixed again bullshit.
