toyota celica gt-4 fuelcut
Postby BR0Z » Mon Feb 14, 2005 8:11 pm
Hi
Pretty sure it's around the 14psi mark, unless it's the RC model which is 17psi 8) .
Cheers, Mark
Oldie but goodie
Mark Bros
91 GT FOUR RC x 3 1 Red (mine) Daniel - 2 White - 1 damaged & for sale =(
May the FOURce be with you
http://toyspeed.blakjak.net/profiles/profile.php?id=244
BR0Z
Postby brownm02 » Mon Feb 14, 2005 8:50 pm
does any one know what the gt4 fuel cuts out at?
cheers.
~1989 Celica GT-Four~
brownm02
Re: toyota celica gt-4 fuelcut
Postby Twolitre » Mon Feb 14, 2005 9:18 pm
brownm02 wrote:does any one know what the gt4 fuel cuts out at?
cheers.
It seems to vary from car to car but around 12-13psi is normal, only one way to find out :wink:
Twolitre
Postby flygt4 » Mon Feb 14, 2005 9:21 pm
what model gt4? and from ur sig i think fuel cut would be the least of ur worries.start saving for clutches,diffs and gboxes :wink:
my st185 cut about 14-15 psi , st165 are similar as well i think.the st205 doesnt cut til sumwhere above 18psi i think. unless you hav an RC edition gt4 or st205 then dont bother with anything above 14-15psi consistently as the wee turbos like to fall apart.plus the ecu doesnt hav fuel maps above 14.5 psi anyway , hence the fuel cut :?
flygt4
Postby GT4 20 » Mon Feb 14, 2005 10:13 pm
WRC ST205 has it's fuel cut at 17psi. Their turbos have steel internals so they don't crap out so easily :D
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby brownm02 » Tue Feb 15, 2005 5:47 pm
yea i got the st185 and think it is time to rise the boost :D and does any 1 no wht the max safe boost is i herd it is arount 16 to 17psi???
brownm02
Postby Twolitre » Tue Feb 15, 2005 5:51 pm
Not with the stock ecu, turbo and intercooler it's not. The stock turbo doesn't give much more power after 14psi anway.
Twolitre
Postby flygt4 » Tue Feb 15, 2005 8:32 pm
aim for 14 psi.you will probly need a fuel cut defender to stop it cutting out on colder evenings.. if you are smart and hav a decent air filter and exhaust fitted already , you will probly struggle to get a steady boost level anyway , so by aiming for 14 you will get anywhere from 13-15.
flygt4
Its for a MR-2 but it might be of some help.
Postby peas » Wed Feb 16, 2005 4:42 pm
This is a link to a site that is all about tuning the 3S-GTE, in a MR-2 but Im sure that there are no major differences other than the RC models and the differing ECU. Might be way off but worth a read anyway.
http://www.mrcontrols.com/primers/fuelCut.htm
peas
Postby brownm02 » Wed Feb 16, 2005 4:47 pm
yea i have an 2.5" exhaust and k&n filter. Is that true about the fuel maps only reading up to 14psi?
brownm02
Postby GT4 20 » Wed Feb 16, 2005 7:31 pm
http://www.gt4oc.net has a very good forum covering the GT4.
Gary
GT4 20
Postby brownm02 » Thu Feb 17, 2005 8:02 pm
cheers has any one here mounted a front mount to one of these??? how hard is it and do they fit under the std bumper
brownm02
Postby GT4 20 » Thu Feb 17, 2005 9:47 pm
Go to the site I suggested. :wink: Masses of info there on FMICs.
Gary
GT4 20
Postby Twolitre » Fri Feb 18, 2005 12:40 am
brownm02 wrote:cheers has any one here mounted a front mount to one of these??? how hard is it and do they fit under the std bumper
Lanius has a fmic on his, there's sweet fa room in the stock front bumper but if you upgrade to an RC bumper it allows for a lot more space up front but there would be quite an increase in lag, If I were you I'd try and find a water-air setup unless you want the bling factor.
Twolitre
