max rim/tyre size for AE5/6
Postby beeker » Mon Feb 28, 2005 6:33 pm
Whats the recommended max rim/tyre size that i run on my AE85/6 for club sport use ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Stealer Of Souls » Tue Mar 01, 2005 9:06 am
What have you done to the car?
A lot of people recommended to me not to go above 15in because in general the suspension setups on AE85/6s will start to get "overpower" by the lateral grip, and start lifting tyres...
But I think if you have some really serious setup you could go a bit bigger, 16s or maybe at a squeeze 17s.
Will also depend on what rubber you're using.
'86 AE85.5 Levin
Stealer Of Souls
Postby beeker » Tue Mar 01, 2005 9:16 am
Stealer Of Souls wrote:What have you done to the car?
Its an AE85 with pretty much all the AE86 bits transferred accross, including the front struts. Its slightly lowered all around, but not overly slammed, as its setup for targa and needs compression ability else she'll bump its way off the road. Its running TRD rears. I didnt do the work, but have recently purchased it from the previous owner/builder of the car. Its a clubsport/targa car with cage etc.
From what you have said, its sounds like sticking with 15" is more suitable. What 15" rim offset and tyre size is recommended as the max ?
06 RS4 Avant
beeker
Postby Drifter4ag » Tue Mar 01, 2005 10:03 am
You can only go so low and wide with 15inch rims before you hit the rear guards.
Only buy wheels that are justified by your brake size
i run 280mm front rotors and 270 rears and im still running 14X7s all round.
Std brakes with stock lower arms and stock track on diff i would go for 14X8s with offset 0 to -10
Garage |-" '|
Current Rides
AE86 Notchy (Finally through compliance after 5 years)
Vitz RS :D
Previous,
1x SXE10 Altezza, 2xAE111 Caribs, 3xKP60, 2xke35 SR Coupes, 2xAE85s, 2xAE86 Road Car, 1xAE86 Drift Car 182kw@wheels, 1xJZZ30 Drift Car 360ps
Panspeed Special 450ps Drift Car
JZX91 MARK II CHASER
JZX81 MARK II CHASER..... so many more that i forgot....
Drifter4ag
Postby Stealer Of Souls » Tue Mar 01, 2005 3:45 pm
I don't know about max. But I can tell you I'm running 15x6.5 +7(I think) offset. 195/50-15s for tyres.
This combo seems to work well with what else I'm running.
30mm lower Kings springs all round, KYB shocks all round, 24mm front stabiliser, TRD 2 way LSD, rear strut brace and half cage.
Stock rotors and calipers all round, so 234 fronts, 225ish rears.
Also just about to put on 18mm rear bar (but scared of results since this will VASTLY adjust the rear bias of the handling), and a front strut brace.
The only way to know what you can run is to try it really. It'll depend on your driving a lot.
If you go for 15s I would suggest starting with some 15x6.5 with 195/50-15s with around a zero offset...
I think biggest changes will be in tyre choice.
I used to run some toyos but found they just wouldn't perform on my car. Got some Yokohamas that seem to perform nicely. Mixture of weight, driving styles etc...
'86 AE85.5 Levin
Stealer Of Souls
Postby beeker » Tue Mar 01, 2005 5:26 pm
Any recommendations for a good source of 2nd hand alloys ?
Also, if i go new, what do you guys think of those superlights ?
I need hard and light.
06 RS4 Avant
beeker
Postby suckymotor » Tue Mar 01, 2005 7:16 pm
hi there just got a new set of rims for my ae86 this week they are a 15x6.5 a p25 of set got them from manukau mag and tyre cost $700 if your going to do the targa you want to get a set of dunlop DO1J the best size i found that fit my car are a 195/55/15
suckymotor
TS Original Member
Postby malc » Tue Mar 01, 2005 7:19 pm
superlights are cool.
get some nice deep ones
malc
Postby Stealer Of Souls » Wed Mar 02, 2005 11:50 am
Integra Type R rims I think will fit. They are some Enkei light weights and can usually be found for as little as $400 in really good condition. Throw away the centre caps and paint them and very few people will notice...
Yoko A032R 195/50-15
Dunlop DO1J 195/55-15
Toyo RA1 205/50-15
--> All "semi" race tyres. Probably what you want for a Targa.
Otherwise try some hypo streeters, but during a Targa don't expect the earth...
'86 AE85.5 Levin
Stealer Of Souls
Users browsing this forum: No registered users and 33 guests
