techo problem
techo problem
Postby BENS 8 » Mon Mar 07, 2005 5:23 pm
The techo in my 95 Corona is giving eratic readings. Have changed coil on bulkhead and igniter on near side by strut in engine bay; no result. Any clues or is the guage at fault and if so are they worth repairing and where can you send them?
BENS 8
Postby Dell'Orto » Mon Mar 07, 2005 6:40 pm
Does it skip around while the car is running? Check your battery leads are tight, and that its getting enough voltage.
Postby atmosports » Mon Mar 07, 2005 6:55 pm
Other thing is check the wires on the back of the diagnostics connector in the engine bay. I have seen many a toyota with the same problem which in many cases is caused by a break in the IG- wire which runs from the ecu to the tacho & also out to the diagnostics connector, the break is normally right under the connector, have a look & see if that solves it.
atmosports
Postby THA SHZ » Tue Mar 08, 2005 10:49 am
Could also be that ur speedo cable has ben bent or has a kink in it at sum stage could check for tht .
THA SHZ
Postby BENS 8 » Wed Mar 09, 2005 5:16 pm
Had a look at the terminals and the diagnostic wires and they look O.K. Any more ideas?
BENS 8
