by RS13 » Fri Mar 11, 2005 7:21 pm
I believe there's a 150kW turbo 5K on Club-K.co.nz, I had a mate a couple of years back with a turbo 4k KP, went hard, but still got dicked by a factory redtop.
I believe he was running a cut n' shut factory exhaust manifold, T2 turbo out of an ET turbo Pulsar, SU carb off a triumph something (TC2500?), wasn't intercooled or anything though, super rangi setup. From memory, it was running 5-6psi, which was the limit for factory pistons etc.. I'm pretty sure it ended up sticking a leg outta bed, had problems sorting out a decent oil feed.
HTH!!
