Stealer Of Souls wrote:Slots are more for "cleaning" the pads...
More slots would scrap the pads "clean" a lot more often. Mostly useful to help prevent glazing. Also help a little with de-gassing and cooling the rotor.
If you want real cooling/degassing then try looking for cross-drilled and vented rotors, or for just cooling ducting...
HRT wrote:if you start playing around with ....... braided hoses and things then you need to get certs (as far as I know)
GT4 20 wrote:ps Don't go posting lots of "But I've got cross drilled and never have any problems". I appreciate that there are cars out there which use them - but there are cars which do have problems with them - either from extremely hard use or poor quality rotors.
Q: Why are some rotors drilled or slotted?
A: Rotors are drilled to reduce rotating weight, an issue near and dear to racers searching for ways to minimize unsprung weight. Drilling diminishes a rotor's durability and cooling capacity.
Slots or grooves in rotor faces are partly a carryover from the days of asbestos pads. Asbestos and other organic pads were prone to "glazing" and the slots tended to help "scrape or de-glaze" them. Drilling and slotting rotors has become popular in street applications for their pure aesthetic value.
ROBODISCO_20v wrote:Anyway for all those out there thinking about putting drilled/sloted rotors on your car, DO IT. You'll be impressed with the improved stopping power, no point having a fast car if it cant stop in a hurry.
ROBODISCO_20v wrote:Dude i wont even bother answer that its such a stupid question.
Sorry i guess i cant expect everone to be upto to play on these sorts of things. Have a read of the DBA web site, you should find some info on there to help you understand how this works
I found the info for you
Slotting increases pad bite, reduces fade and delivers better braking performance. The slotts continually de-glaze the pads improving efficiency. They wear evenly across the pad faces increasing the effective contact area. Slots help dissipate water as well as pump away dirt & dust. Slotting and drilling also combats "out-gasing", where gas from the pad bonding agents can form a cushion between pad and rotor, greatly reducing braking power.
There, i hope that helps
