20V Missing - Help?
20V Missing - Help?
Postby Sanxta » Tue Mar 15, 2005 11:50 am
Yo, so as above my car is bogging down/missing when the accelerator goes down. Ive done the leads and spark plugs, and the air intake isn't blocked or restricted.
What else could be the cause of this? I'm gonna reset the ECU tonite but I doubt that will do anything for my case . . .
Cheers for any help,
Adam
Sanxta
Postby pc » Tue Mar 15, 2005 12:13 pm
Not sure, but could this be a faulty TPS? (throttle position sensor)
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Sanxta » Tue Mar 15, 2005 12:35 pm
possibly - the car goes no where for a bit then suddenly jerks - does that sound like the kind of symptom caused by a faulty TPS?
Sanxta
Postby Fuct Munkey » Tue Mar 15, 2005 6:15 pm
sounds kinda like what mine is doing on mid to full throttle it will misfire till it feels kinda like vvt is engaged. but mine only does it when warmed up. so it makes it all or nothing. sad part is, just put a new engine in, to try fixing it ive just done plugs, leads, cap, rotor, coil, ignition module. . . no such luck. checking wiring next, then ecu, also replaced tps, and adjusted numerous times, also tried adjusting timing. :roll:
Fuct Munkey
Postby slowke » Tue Mar 15, 2005 6:17 pm
same thing is happeneing with my mates legacy. in his case it is the afm not running properly, check that
bugeye in the build....
slowke
Postby Mr. Mainstream » Tue Mar 15, 2005 6:47 pm
do you need the throttle position sensor on 20V's? On B6T they can go in the bin
Current:77 MK2 Ford Escort L 1.3L
75 MK2 Ford Escort L 2.1L
Had: 2X Early Subaru Leggys GT Wags, 1X Subaru RS, 1X 2004 Subaru B4, 2x BFMP Turbo Sedan Famil's, 2x BFMR Turbo Sedan Famil's, AE92 FX-GT, 97 Holden Calais 3.8L
Supercharged 12psi ,Escort, BZ-R
Various Others
RomanV wrote: Mr Mainstream: The king of the Pushrods?!
Mr. Mainstream
Postby bad20v » Tue Mar 15, 2005 8:00 pm
Fuct Munkey wrote:sounds kinda like what mine is doing on mid to full throttle it will misfire till it feels kinda like vvt is engaged. but mine only does it when warmed up. :roll:
If it does it @ bout 3500 rpm when you slightly back off the throttle then, according to sum technician guy @ toyota, its a factory fault. I had the same problem in my ae101, he said it's a change from the engine being on vvt and coming off vvt. Sort off like the opposite effect of when vvt kicks in. Thats jst wat ive ben told.
Thank-You.
bad20v
Postby offensive » Tue Mar 15, 2005 10:07 pm
my 101 used to do it, especially when it was warming up, when it was at running temp it would settle down abit. Back then it was running a blacktop with silvertop ecu, afm etc. As soon as it got running blacktop ecu, map it stopped doin it, runs sweet now.
above this is a line
quote: "Reclusive girls dont shave their pubes"
offensive
Postby Fuct Munkey » Wed Mar 16, 2005 8:57 pm
nah, like my car becomes undriveable. unplugging the TPS makes it run better, less repsonsive, flat, but not so missing like. yea, havnt really tested the AFM mite giv that a go. anything is a good idea at the mo, its seriously sick! if someone told me to stick an apple in the engine bay to fix it i would probably giv it a go.
Fuct Munkey
Postby sergei » Wed Mar 16, 2005 9:52 pm
check ignition coil (listen if it makes static sound, look if it glows at night)
check if tps set properly -> use multimeter in Volts, measure voltage between red wire (3rd if you counting from front of car) on tps, and GND, it should read 0.5V (500mV) if not adjust TPS, then slowly open and look at the voltage, if its steadily increasing whithout jumping to 0 in some spots its all sweet, after you done that reset the computer, don't open AFM it will lead to no good, there is nothing there to adjust.
Postby mr20v » Thu Mar 17, 2005 8:23 pm
my mates blacktop did the same thing but due to a disconnected lambda sensor, or perhaps a knock sensor. just chugged away in the when accelerating at a middly sort of level but fine when accelrating hard or real softly.
'84 20V AW11
'89 FX-GT w/ half-cage (MADFX - anyone want to buy a number plate?)
Click here for fancy porn!
mr20v
Postby Truenotch » Thu Mar 17, 2005 8:36 pm
My ae86 was doing the same thing, no power till 2500. All it was in my case was a split hose from the plenium to a sensor on the firewall. Put on a new one and it ran sweet. Could pay to check them out maybe.
Truenotch
