auto to manual (again) different Q's
Postby MR2boy » Sat Mar 19, 2005 4:58 pm
Im going to change the gearbox in my sisters starlet from auto to manual, I know what has to be done thats not the issue
I would like to know if I have to tell the LTSA about the change? will it cost anything? will it need a cert?
I have searched but it came up with a million pages and no specific answer to what im after
Kurt
**** Car here ***
MR2boy
Postby Silent Knight » Sat Mar 19, 2005 5:25 pm
i think you require something like a low volume cert if you change it from auto to manual but i can't confirm this.
if you do a good job and have a manual console etc to go with the conversion then no one will be able to know what the car was suppose to be unless they decode your the numbers on your Vin/chassis plate.
Silent Knight
Postby AE85coupe » Sat Mar 19, 2005 8:16 pm
yeah man i never had any problems with warrents when i changed my 85 from auto to manual, they just didn't know any different heh
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Dr-X » Sat Mar 19, 2005 8:22 pm
No.
Dr-X
Postby Mr Revhead » Sat Mar 19, 2005 9:33 pm
if it all bolts in (which it will) then no
if you have to weld and cut etc (which you wont) then yes
Postby RS13 » Sat Mar 19, 2005 10:59 pm
Yup.. as long as you use ALL the parts from the donor manual, ie. if its a RWD Starlet, get the manual crossmember and driveshaft, if its a FWD Starlet, use ALL brackets and mounts that came from the donor.
The idea is, if you have to make up ANYTHING, it needs to be certed, but as long as they're all bolt-up factory parts, you don't.
RS13
Postby MR2boy » Sun Mar 20, 2005 8:56 am
Im just gonna be using all the manual parts from dads rusted starlet so should be ok then
Thanks
Kurt
**** Car here ***
MR2boy
