Me - "I push very, very hard on the pedal!"
TRDmod wrote:hendce why i made it clear i wasnt deluding myself, but, therotically it should help when i am workign the brakes hardcore....so ill see when i go to puke
Adamal wrote:Exactly what gas is inbetween the rotor and the pad here?We're not talking about 'air' are we? Cause thats dispersed easily enough isn't it?
GT4 20 wrote:Adamal wrote:Exactly what gas is inbetween the rotor and the pad here?We're not talking about 'air' are we? Cause thats dispersed easily enough isn't it?
However, my understanding is that this was more of a problem with the old asbestos type pads and is not really an issue if the pads are bedded in properly in the first place.
If they are bedded in properly, then the likelyhood is that for normal roda use, you are unlikely to get the pads hot enough to warrant the requirement for slotted rotors. Much more likely to be needed on the circuit or for legal fast road use - such as a hillclimb etc.
Gary
certain pads will have better "feel" and others will be more grabby.... certainly some are more prone to locking, as in they will suddenly snatch.
nope.
try running junk yard pads...... then go get some good mintex or similar.
wheel will lock with both, but it will lock first at a higher speed with the junkyard pads.
ie: junkyard pads won't slow you down as much before lock.
Same tires.
i tested this many times.
