3S-GTE ID Help (PIX)
Postby Corona » Tue Mar 29, 2005 11:48 pm
Hi,
I need some help ID'n some parts on my 3S-GTE to see if I need to ether block up the hoses, or find out what needs to connect to them
The first pic below shows a hose that has been broken off at the timing belt end of the manafold.
Here there a several parts that are missing conecetions.
The one from the Rocker cover obviously needs to go the the manafold somewhere, where shal I connect this?
The ones from the throtle body (the pipe winds from one to the other and has sereral other connections comming from it as well), shall I just block them off, or should something else be connected there?
Which one of the Manafold ones are connected to the Turbo presure sensor and MAP sensor?
These pipes are just hanging there at the moment, I know someting was connected up at some stage, as they both have broken connectors on them. What went here?
Any help would be appriciated
Thanks
Neil
Just remember: The glass is neither half full nor half empty, it is merely the wrong size
Corona
Postby Twolitre » Wed Mar 30, 2005 12:11 am
The vacum hosing on the first pic goes to the fuel pressure regulator and the other one goes to the map sensor which is usually on the firewall.
Third pic hoses go to the valve on the bottom of the PS pump which is missing on your engine.
Might pay to no. all the hoses on the 2nd pic and then I can tell you where they all go.
Twolitre
Postby Corona » Wed Mar 30, 2005 12:37 am
Pic Edited
Thanks for the Info on the First Pic. I thought that there was a MAP sensor missing somewhere, but thought that it was from the other end of the manafold
On the last pic, there was no connections on the P/S pump that these hoses could have connected to. I havent looked on my car yet, but the engine is out of a Celica. I belive that the engine was origionaly AllFours, he might be able to shed some light on what they were connected to.
I belive that there might be an A/C Idle up missing was well
Corona
Postby Twolitre » Wed Mar 30, 2005 12:03 pm
Nope, they connect to the idle up valve on the base of the power steering pump, all 3S engines are like that although the nipples on the valve are easily broken off during engine removal and installation.
A= inlet piping after AFM, just connect it to a catch can or whatever
B= Charcoal cannister, if you don't have the charcoal cannister or don't intend to use it just block this hose off
C/D= these go to either side of the airccon vsv which you don't need, just block them off too.
E= this supplies air to the engine when the throttle is closed, ie idle. You need to duct this to filtered air after the air filter or just put a little filter on the pipe but it will be rather noisy.
Twolitre
Postby Corona » Wed Mar 30, 2005 6:54 pm
Twolitre wrote:Nope, they connect to the idle up valve on the base of the power steering pump, all 3S engines are like that although the nipples on the valve are easily broken off during engine removal and installation.
Ok. O'll have to have a closer look on the P/S pump to see where they come from next weekend when I go back up north again.
Twolitre wrote:A= inlet piping after AFM, just connect it to a catch can or whatever
Sweet
Twolitre wrote:B= Charcoal cannister, if you don't have the charcoal cannister or don't intend to use it just block this hose off
I probably wont use it, but what are they used for?
Twolitre wrote:C/D= these go to either side of the airccon vsv which you don't need, just block them off too.
I will have Air Con, so I might need these?
Twolitre wrote:E= this supplies air to the engine when the throttle is closed, ie idle. You need to duct this to filtered air after the air filter or just put a little filter on the pipe but it will be rather noisy.
Easy enough to do.
Thanks
Corona
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
