Dr-X wrote:You'll be fine on 91.
90% of cars in NZ should be run on 91, but something like 35% of people are using 96.
ROBODISCO_20v wrote:Dr X you're a fcuking idiot
ROBODISCO_20v wrote:Dr-X wrote:You'll be fine on 91.
Where did you get this info from? The vast majority of cars in NZ are jap imports and like mr revhead said the min they got in japan is 96 not 91. So they should be run on 96![]()
Dr X, everytime you post here you say something stupid.
Dr-X wrote:The vast majority, these days, of cars are NZ new.
Guess what? We use a neat little thing called a knock sensor that virtually eliminates pinging.
Do yourself a favour and read a book moron.
fivebob wrote:Dr-X wrote:The vast majority, these days, of cars are NZ new.
Define Vast majority? Typically NZ New cars make up about 25% of the first time registrations, hardly a majority and most definitely not vast
Guess what, a knock sensor is only useful if the car is tuned for the appropriate fuel, otherwise it's just a recipe for a blown engine, because the engine is constantly going through the cycle of knock/retard/advance/knock... which is not good for piston life
Define Vast majority? Typically NZ New cars make up about 25% of the first time registrations, hardly a majority and most definitely not vast![]()
Guess what, a knock sensor is only useful if the car is tuned for the appropriate fuel, otherwise it's just a recipe for a blown engine, because the engine is constantly going through the cycle of knock/retard/advance/knock... which is not good for piston life. Knock sensors are good for the occasional batch of low spec fuel, not for the constant running on fuel below what the engine was tuned for.
Mr Revhead wrote:well i was gunna say a lot.. but vega and five bob beat me to it....Guess what, a knock sensor is only useful if the car is tuned for the appropriate fuel, otherwise it's just a recipe for a blown engine, because the engine is constantly going through the cycle of knock/retard/advance/knock... which is not good for piston life. Knock sensors are good for the occasional batch of low spec fuel, not for the constant running on fuel below what the engine was tuned for.
another reason to tune the timing to suit the fuel is 20vs, the factory setting are 10deg, but they hit the knock sensor, so settign them to 8 stops them hitting the sensor, which knocks em back 4-6 deg i think.
makes for smoother running and longer life.
