deaf_rattle wrote:you may find that you think its more powerful from running the higher octane, with reality being you are just thrashing it more.
Lighten the foot abit and watch your economy go up.
KiwiMR2 wrote:Do you have a NA or Turbo MR2??
KiwiMR2
FST4RD wrote:260k's out of a tank???
I put $30 in my SW20 GT, which filled it up about half and managed to get bout 170k's out of it driving it conservativly.
I can definatley get well over 300k's out of a tank.....
Do the n/a's have a smaller tank than the turbos???
Mr Revhead wrote:resetting the ecu wil only make a difference if the ecu has a learning capability... and most dont. id be suprised if it makes any difference in any post 2000 toyota. they may have a knock sensor memory.....
they only way to tell for sure would be to do dyno runs with good diagnostic gear hooked up.
using fuel that fast it must be blowing a hell smoke cloud....
id say your problem is else where, not with the fuel. sw20s need at LEAST 96....
KiwiMR2 wrote:Iv'e forgotten if it was ever proven BUT a lot of people reset the ecu so the car can re-learn.
ECU learns and adapts depending on factors like fuel quality, knocking, and climatic factors. Over a period of time, the ECU may develop a conservative fuelling map which robs the car of performance (or if a problem occurs, e.g. bad fuel or an engine safety scenario.) Although the ECU continually adapts, it's very slow at doing so and can be reset to speed up the process.
Preferably after a drive (and the car now at full operating temperature), park, remove the key, and wait a couple of minutes. In the engine bay is a fuse box -- remove the 7.5A ECU-B and 15A EFI fuses. In the front compartment (not the cabin), remove the 7.5A ECU-B fuse... and then wait for at least two minutes before replacing them. With the fuses re-seated you can start the car and go for a drive, and being already warmed up you can drive the car hard if you wish (showing the ECU exactly how it should be fuelling!)
Don't be alarmed if the car is sluggish at first -- the ECU has been reset and is having to learn from scratch. If it's reset when the car is cold, the lack of performance and hesitation will be more noticeable, but will still pass after a good 10-15 minute journey where the throttle can be exercised.
NOTE: Resetting the ECU not only removes the existing fuelling map but also any error codes which were stored. This is handy for any one-off events which may have placed the ECU in 'safe mode' but should a problem still be evident then the ECU may instantly revert back to its conservative settings. If this is the case then the issue(s) should be addressed accordingly.
KiwiMR2
