Flat Spots
Flat Spots
Postby dotdog » Mon Apr 04, 2005 3:58 pm
Hey all, seems my car (Ep71 Turbo S Starlet) has developed a bit of a flat spot (and not the sort that is on the back tyres). I put a earthing kit on and ever since it seems to have had a massive flat spot between 3K and 4K, when its on boost, which is bout 13-14psi, ive played around with the fueling, timing, plug gaps and seem not to be making much progress, anyone got any ideas, cause its got me stuffed
dotdog
Postby Adydas » Mon Apr 04, 2005 5:44 pm
tryed changing the plugs Checking the Rotor? leads
it sounds simlar to what my EP82 was doing when the rotor was on its last legs.
another thing was the spark plug lead had a crack and was arcing onto the barrel of the head. causeing problems
But check the basics first
Plugs leads rotor
Adydas
Postby dotdog » Tue Apr 05, 2005 1:20 pm
Bump, ive ordered a new dizzy and rotor cap to eliminate this
dotdog
Postby Adydas » Tue Apr 05, 2005 5:57 pm
Did it fix it.. or still working on it?
Adydas
Postby dotdog » Tue Apr 05, 2005 6:24 pm
waitin on parts still
dotdog
Postby matt dunn » Wed Apr 06, 2005 12:19 am
does it feel like it's missing or just loosing power?
Postby dotdog » Wed Apr 06, 2005 1:24 pm
It feels like its losing power, even surging abit and as soon as it gets past sort 4100 its way again
dotdog
