Controlling ignition with Megasquirt. VAST or ESA?
Postby ChaosAD » Fri Mar 25, 2005 1:58 pm
Ive recently been putting together a kitset ECU known as the Megasquirt to run my 4age. I was going to use the megasquirt as a fuel-only ecu till I found this. http://www.msefi.com/viewtopic.php?t=5417&highlight=4age&sid=9c877d97ddc29dd3f13ea5acbcee48d2
My question is what sort of ignition system do out JDM map sensored bluetops run? VAST or ESA?
ChaosAD
Postby slighty_sykotic » Fri Apr 08, 2005 12:08 am
Same questioin here, what ignition does a 20v silvertop have?
--Sykotic
slighty_sykotic
Postby slighty_sykotic » Sun Apr 10, 2005 6:37 pm
BUMP 8)
*innocent look*
--Sykotic
slighty_sykotic
Postby ChaosAD » Sun Apr 10, 2005 8:33 pm
ChaosAD
Postby slighty_sykotic » Sun Apr 10, 2005 9:06 pm
I went to download the PDF, then reliesed that its exactly the same one i found the other night. Where in it does it _DEFINTANTLY_ say it? I probably missed it, but i got a strong impression that its a VAST system, but i couldnt see weather it clearly stated yes or no.
Thanks though,
--Sykotic
slighty_sykotic
Postby pidge » Mon Apr 11, 2005 1:17 pm
slighty_sykotic wrote:I went to download the PDF, then reliesed that its exactly the same one i found the other night. Where in it does it _DEFINTANTLY_ say it? I probably missed it, but i got a strong impression that its a VAST system, but i couldnt see weather it clearly stated yes or no.
Thanks though,
--Sykotic
Last paragraph page 6:
The VAST system is only used on the 2S-E, 22R-E, 22R-TE, 4Y-E, and 4A-GE engines.
I don't know if this applies to the 20V as well as 16V engines.
pidge
Postby slighty_sykotic » Mon Apr 11, 2005 2:09 pm
Yeah, thats why i'm not completlely sure, cause it doesn't say that ESA isn't used on 4age engines aswell... See what I mean?
But yeah, it's most probably VAST, ill have a proper look tonight at my car.
--Sykotic
slighty_sykotic
Postby ChaosAD » Sat Apr 23, 2005 5:54 pm
It seems like my system is the ESA system. It has a 4 tooth wheel and a 24 tooth wheel in the dizzy and no wires go from the dizzy to the ignitor.
I posted a few questions on the Megasquirt site http://www.msefi.com/viewtopic.php?p=48609#48609 I have a feeling it may work.
ChaosAD
Postby slighty_sykotic » Sat Apr 23, 2005 11:46 pm
After a VERY long search, yup, my car (20v silvertop) is ESA ignition also.
Going to pick up a HEI module on monday aftanoon hopefully, if not tuesday from repco (shouldn't be too expenisive). Let me know how you go chaos. Will be interesting.
--Sykotic
slighty_sykotic
Postby vvega » Sun Apr 24, 2005 12:02 am
the 20v and dli type ze ignition as well as the smallport redtops all use the same ignition system trigger wise
this a is a 24 tooth multi tooth signal wheels and a 2 point home (sync) signal
it takes the home signal and counts teeth to find spark and fueling points ,this is a true crank angle system
all the bigport 4age engines use the 4 point ignition signak and the 24 tooth multitooth
this enables the ecu to control dwell and advance but basically the dizzy controls the spark timing from each pulse of the 4 tooth the 24 tooth enables a shaper resolution for the fueling as the 24 tooth in the bigport 4ages only contols the fueling :D
hope this has helped
v
vvega
