ahaha
dam that was some effort there akane
LOL
you should ALWAYS bleed ya brakes on a pad change the more you can bleed it the better
eliminates any water build up in the system.
from memory they are the ratchet style caliper hence the wind in.
and it is easy to bleed brakes as a one man band
just need a pole or stick of the right length to hold the peedle down
